Replacing the cuppler this weekend- can you help? >
Old 07-23-2007 | 02:35 PM
Default Replacing the cuppler this weekend- can you help?
I am new here and this is my first post. I look forward to learning from this website. I am a member of many car forums and know how extremely resourceful they can be.
Here is the story-
My father has a 1999 33 outlaw with 454's. Over the weekend he "spun a cuppler" in the starboard engine/drive.
He informed me that we will be changing this this weekend and I find myself not feeling too comfortable about doing/helping with this unless I know more.
I know that we need to pull the engine but I need to know if there are any special or sneaky things we should watch out for when doing this. Any special tools we should get? Any advice is greatly appreciated.
Is there a DIY I can see or does has someone else here dealt with this?
Talk about jumping in head first huh?
Thanks a bunch
dcroghan is offline
Old 07-23-2007 | 03:19 PM
Quinlan's Avatar
Do both! I spun my 2nd out less than 10 hrs later.
Quinlan is offline
Old 07-23-2007 | 03:31 PM
Tahnks for the reply.
did you personally do it? If so, how tough of a job was it? It doesn't seem too tough, just alot of heavy moving. Rough estimation of hours to complete?
Anything i shoud look out for upon reassembly?
dcroghan is offline
Old 07-23-2007 | 03:32 PM
Make sure you have the Alienment tool for when tou put the engine back in. Otherwise you are going to yave major problems.
John the Drive Man is offline
Old 07-23-2007 | 03:36 PM
The coupler tool is denifately a must but it should align very easily as your are installing the same engine in the same spot. Don't worry about the job, you will get through it, Alignment is everything but simple. Estimate? all weekend.
ghittner is offline
Old 07-23-2007 | 04:42 PM
It can be done without pulling the engine completely out if you have enough room to pull it forward. It might be tough to get between the engines though. Only special tool is the alignment tool. Alignment shouldn't even need to be touched if you pull the front mounts without messing with the adjustment. The job can be done in one day if you have the motivation. My experience is that once the engine is out, you'll always find something else that you want to take care of as long as the engine is out. BTW, I did my engine install by myself since nobody was around to help that day so it can't be that tough.
Rene
oldandtired is offline
Old 07-23-2007 | 05:19 PM
t500hps's Avatar
21 and 42 footers
Thios past Sat:
4 guys with day jobs but we've done this before.
Started at 8:00. Pulled steering and drive, "de-rigged" motor and pulled it out of the boat. Dropped accessories and anything else needed to drop the oil pan. Found the pickup tube laying in the bottom of the pan, Went to 6 stores to find a replacement pickup tube. Re-installed pump, oil pan, etc. Re-installed motor, re-rigged, installed drive/steering and set timing. Got the boat running and DONE!!! at 1:00
If you have the equipment to lift a motor then your not complete rookies. Take your time and be careful. (alignment is your only issue once completed)
t500hps is offline
Old 07-23-2007 | 05:27 PM
I actually did an exchange and replaced the flywheel with the engine still resting on the front mounts. I don't recommend it as it was very tricky. I had no lift but had enough room to rock the back of the engine up enough to loosen the coupler bolts. If you have a lift, pull'em, especially with two. Have some one look @ the shafts for splin damage. Keep them greased.
baronbob is offline
Old 07-23-2007 | 11:49 PM
If you don't get it aligned correctly and run the boat, you will replacing the coupler again within 10 hours.
Griff is offline
Old 07-24-2007 | 11:24 AM
thanks for all the replies. We do have the alignment tool so we are hoping that everything goes semi- smoothly even though I know it won't cause it never does.
How can you tell when it is aligned perfectly?
Will the tool be able to freely slide in and out? I am assuming that if there is any type of friction upon inserting the tool that it is not completely aligned. Does that sound right?
Also, out of curiosity do any of you know how much one of these engines weigh?
thanks again
dcroghan is offline
