HP 500 Blown UP? >
HP 500 Blown UP?
HP 500 Blown UP?
Old 07-23-2007 | 06:22 PM
Default HP 500 Blown UP?
Ok was in a poker run this weekend when running about 4000 rpms all was ok. Slowed down and bam Port motor just shut off. Tried to restart but just smoke out of the exhaust and intake? Let it sit for a while then tried to start it and it ran but real bad with a miss. Shut it down and loaded it up on trailer. Got home pulled the plugs and Number one spark plug looked like someone hit the tip with a hammer. Checked for compresion and there is 0 Any ideas? Just a valve? Worse?
GoFastSonic is offline
Old 07-23-2007 | 06:29 PM
OldSchool's Avatar
Sounds like a valve broke and bounced around in there. Pull the valve cover.
OldSchool is offline
Turbojack's Avatar
in a word "detonation. "
Plan on taking motor apart. Will find either valve parts missing, part of the piston missing, and or both.
Could be from getting hot, bad gass, too much timming, 2 lean at that throttle setting, bad fuel pump, & ???
Turbojack is offline
Old 07-23-2007 | 06:38 PM
Never got hot and is a twin engine boat. Got fuel the night before at the marina?
Old 07-23-2007 | 06:45 PM
H2Xmark's Avatar
if you slowed down real fast water might have backwashed in the exhaust, pull the head and take a look, cold water can make the valve seat drop
H2Xmark is offline
Old 07-23-2007 | 07:45 PM
That is what someone else said. It is at the race shop so I hope to find out soon. Thanks for the help
Lofty
07-26-2007 06:25 PM
Strip Poker 388
12-11-2004 04:52 PM
Panther
12
10-16-2004 07:21 PM
bajah2x105
22
07-16-2002 04:30 PM
