Fuel Coolers ??? Is this a Bad idea or not?
Maybe a silly question, possibly even stupid...........
But I have the Eickert dual cooler bell housings, which I do not need the coolers for my application. Is there any reason it would be foolish to run the fuel through there and use it to cool the fuel ? If it's ok it seems it might work real well. Thanks for your thoughts Jon |
1 Attachment(s)
Another good use is to run -4 lines from a spare bell housing cooler to valve spring oilers.
Originally Posted by BenPerfected
(Post 2210009)
ther eare no stupid question's. and yes it is good to cool the fuel especially when the engines are suprer charged.
Originally Posted by monstaaa
(Post 2210462)
there are no stupid question's. and yes it is good to cool the fuel especially when the engines are suprer charged.
Is there any reason NOT to run it through the bell housing coolers though? Thanks to every one for your input. Jon |
I expect you are be plowing new ground. If you decide to test the fuel cooler concept, maybe you rig it with a switch to by-pass the cooler so you can do a back-to-back comparison.
(Post 2211043)
Not a bad idea Thanks Jon |
