trim pump hose through hulls >
Old 07-28-2007 | 05:13 PM
Default trim pump hose through hulls
We are rigging twin 300xs on a 32' Midnight and are trying to find through hulls for the trim hoses. Our original plan was to run the hoses down through the bracket then through the transom, but could not find the correct fitting to go through the top plate of the bracket for the Mercury crimped hose fitting on the end of the trim hose. Now we are thinking about just routing them straight through the transom, but need some sort of fitting to get through. Not a standard through hull, but a something that the hose could go through and be sealed. Any ideas? Or if anyome knows where to find a fitting to take the hose through the top plate of the bracket, that would be even better.
jbutah is offline
Old 07-28-2007 | 07:34 PM
jhiguy377's Avatar
yeah, perhaps those compression through-hulls that are sold for the morse 33-c used for trim indicator cable;its close to the same diameter; i think rex marine, hardin or teague sell the fittings; had 'em on my old scarab and they looked and worked great. good luck -jeff
jhiguy377 is offline
Old 07-29-2007 | 07:19 AM
i'd contact marc at bam marine , he makes trim lines so i'd think he would have a lead on thru hulls.
open87 is offline
Old 07-29-2007 | 08:47 AM
Audiofn's Avatar
Charter Member #232
I think that both Stainless Marine and Lavorsi make somthing that will work for you.
Jon
Put your best foot forward!
Audiofn is offline
Old 07-29-2007 | 07:11 PM
these are the hoses we could not find the fittings for
We ended up just fabricating our own through hulls
Mark, I would be interested to see how they did your Concept if you have time to take pics.
jbutah is offline
Old 07-30-2007 | 11:57 AM
Thanks for the photos.
Is the black thing the trim hoses go through watertight? How do the hoses go through your transom in the bracket?
Looks like Concept does a really nice job.
jbutah is offline
Old 07-30-2007 | 01:19 PM
Audiofn's Avatar
Charter Member #232
The black thing is water tight. I used one on my hydrostream. They work real well. Looks like they have hard line going around the tilt tube?
Jon
Audiofn is offline
Old 07-30-2007 | 02:34 PM
Jon
Where did you get one of those black things?
jbutah is offline
Old 07-30-2007 | 08:34 PM
Mark,
Thanks I really appreciate you doing all that. Did you get yor lower unit fixed yet?
Thanks again,
John
jbutah is offline
Old 07-31-2007 | 12:48 PM
Originally Posted by marylandmark
Yep- lower came in last week. Merc racing said it would ship on 7/31, it was at the shop on 7/25 and I was on the water 20 minutes later!
Do you need more angles or pics or ____?
Good news on your boat!
No more pics neccessary, just trying to see how everybody does this riigging thing. Getting the engines hung on the transom is the easy part. It is the rest that is complicated.
Thanks again
jbutah is offline
spk1
4
07-28-2006 02:12 PM
CNC
2
06-10-2006 07:36 AM
ratman
01-26-2006 07:48 PM
32fever
6
08-14-2002 03:11 PM
