How does this setup keep from ingesting water? >
Old 07-30-2007 | 03:15 PM
Default How does this setup keep from ingesting water?
I LOVE the look of this setup but it doesn't seem very safe? I'm guessing the coupling about 12" from the tip would be a flapper? But when the engines are shut down wouldn't there be water sitting on top of the flapper which would eventually get past it and into the engine? Is there something to this setup that I'm just not seeing or Is it a REALLY SICK part of closed cooling type system?
32HustSS is offline
Old 07-30-2007 | 03:37 PM
It looks like a completely dry exhaust... no water ever gets in the tailpipes (unless maybe some rain if it wasn't plugged)
jackhammer is offline
Old 07-30-2007 | 04:26 PM
No water comes out the tips. The water that circulates goes into the fitting and hose at the endo the pipes and gets dumped through the hull at another location.
Griff is offline
Old 07-30-2007 | 04:38 PM
Gotcha...Im really interested in building a setup like this for my boat. Are the headers on these setups usually double walled and cooled as well?
32HustSS is offline
Old 07-30-2007 | 10:24 PM
They are double walled with water circulating in between. The only difference is that instead of water mixing with the exhaust gases, it goes out the dump hose. They are considered dry pipes and they are VERY VERY LOUD!!!!!!!!
Griff is offline
Old 07-31-2007 | 12:09 AM
dkwestern's Avatar
Is this why some of the outerlimits have like 6 streams of water coming out the back while they are running? XXX for example. One for each header, and one for the intercooler.
dkwestern is offline
Old 07-31-2007 | 07:30 AM
Ted G's Avatar
Yes, they dump huge amounts of water when running.
www.cbpba.com
Ted G is offline
Old 07-31-2007 | 11:31 AM
Interesting....So, Does the cooling in the risers alone pull the heat away from the headers or does the header itself get cooled as well? Any of you guys have any pics of a setup like this with the hatch down?
32HustSS is offline
Old 07-31-2007 | 12:45 PM
Ted G's Avatar
The water completely encases the headers and pipes, injected below the headers, runs up the pipes, and then out the dumps. They are way loud and a huge help with big cams that would normally have reversion issues.
www.cbpba.com
Ted G is offline
Old 07-31-2007 | 12:47 PM
everything is double jacketed, tube with in a tube, that is why they cost$5000 and up.
excalibur32 is offline
