Quicksilver Throttles >
Old 07-31-2007 | 01:01 PM
Default Quicksilver Throttles
Where do I find the model #'s?
I have a 1984 Chris Cat with Merc 400's
The throttles are the Box kind sitting on the center console, single lever. I need to adjust neutral safety switch and get one of the plastic buttons for the neutral/throttle engagement.
Wannabe
wannabe is offline
Old 08-01-2007 | 05:20 AM
Iggy's Avatar
Try www.mercruiserparts.com (aka BAM Marine).
Find your throttle controls and you can order parts direct.
What out drives you running?
On my system the neutral safety is on the engine. Simple adjustment. Place shifter in neutral and look at the switch mounted on the engine bracket. Switch roller should be centered in the notch. Adjust cables or switch to correct.
Iggy is offline
Old 08-01-2007 | 09:05 AM
Iggy- thanks- Runnin Speedmaster 2's w/ Velvet drive transmissions (BW 72C).
Wannabe
wannabe is offline
1BIGJIM
Prop Talk
3
07-19-2006 07:18 PM
UNSANE
5
05-11-2006 08:17 PM
AbsolutlyScarab
06-08-2005 01:08 PM
Dusty Times
03-19-2004 08:12 AM
Shah Mat
1
10-14-2002 12:11 PM
