Is this a fuel pressure problem? >
Old 08-20-2007 | 11:10 AM
tbl
Always good to measure the problem and confirm root cause before buying parts. Personally I wouldn't buy a pump until you confirmed your fuel pressure is out of spec when the problem is occuring. Pressure may drop off due to volume which points to a fuel pump issue (assuming no leaks from pump to fuel rail, injectors, etc.). If it is a failed regulator, when you restrict the return line you'll see the pressure increase to the pumps max potential which should be at least a few psi higher than spec. What is the fuel pressure specs with and w/o vacuum hose attached?
tbl is offline
Old 08-20-2007 | 11:17 PM
Regulators fail on the low side too when rpm's are on the high side. I forgt to factor that into the equation. Good call
jeff1000man is offline
Rage
0
05-06-2008 11:00 AM
ComfortablyNumb
14
08-17-2007 08:01 AM
BAD-HABIT
9
05-06-2003 03:08 PM
J240
21
08-26-2002 11:00 PM
Kokopelli
7
06-17-2002 09:16 AM
