Another fuel pressure problem >
Old 08-14-2007 | 08:52 PM
Any idea how high the pressure is on the return side?
Plane Silly is offline
Old 08-14-2007 | 09:31 PM
I've noticed some slight variations in fuel pressure from time to time. This time out is was about about 7 to 10 psi variations in the gauge. Really caught my attention. This setup worked fine untill last Friday.
I don't know what the return line pressure is at.
Been crawling aroung in the bilge this evening. Don't see anything visually. It would be nice if an air leak would translate into a gas leak but it doesn't always work that way. I'm getting new filters tomorrow, but I'll have to wait to the weekend to check the plumbing. I don't want to pull all the lines while the boat is inside the garage.
ComfortablyNumb is offline
Old 08-14-2007 | 10:18 PM
thunderusone's Avatar
When running returns on dual tank setups, imco makes a nice switching valve for EFI setups for dual tanks. Supervalve six port. Works great!
http://www.imcomarine.com/pages/tanks.html
thunderusone is offline
Old 08-16-2007 | 02:14 PM
Just Finished Fixing A Fuel Pressure Problem Where It Was Sucking Air In The Gasket On The Fuel Water Seperator. The Filter Did Not Leak A Drop. Check Gaskets On That.
Jb-fse is offline
Old 08-17-2007 | 08:01 AM
Hopefully it's that simple. The filter will be swapped out tomorrow.
Rage
0
05-06-2008 11:00 AM
rangerrick63
11
08-20-2007 11:17 PM
BAD-HABIT
9
05-06-2003 03:08 PM
J240
21
08-26-2002 11:00 PM
Kokopelli
7
06-17-2002 09:16 AM
