fresh out of ideas >
fresh out of ideas
fresh out of ideas
Old 08-16-2007 | 09:29 PM
Blue by You's Avatar
FIERCE ALLEGIANCE
Originally Posted by jhiguy377
oh yeah, I forgot to mention- I just finished pressure testing the headers and tailpipes; several minutes at 45 psi with spikes to 70 psi - bone dry. Thanks - Jeff
Pressure test the block. This will tell you if you have a big job on your hands. Don't forget you need to retorque the intake bolts...after you run it.
Blue by You is offline
Old 08-17-2007 | 08:08 AM
Did you check the head and block with a straight edge to make sure there was no warping?
Screamin' Seamen' is offline
Old 08-17-2007 | 12:48 PM
Lofty's Avatar
before you tear down. Run motors until hot. Idle around for a few minutes then shut down. Pull the exhaust manifolds away (not off) and see if there is any moisture in the runners. This is the only way to check for reversion.
Lofty is offline
Old 08-17-2007 | 01:55 PM
jhiguy377's Avatar
*lofty, thanks for the clarification. was wondering how i'd check that.
*screamin, damn, i did not do that - proably have to next.
*bluebyyou, i did not retorque intake bolts - will do; and what's the best way to pressure test the block?
Thanks to all - jeff
jhiguy377 is offline
THEJOKER
05-16-2003 10:12 AM
rick32
11-20-2002 04:52 PM
CelticPride
Sonic
3
10-30-2002 07:08 AM
Tinkerer
Scarab
1
08-30-2002 09:05 AM
