water wich wiring >
water wich wiring
water wich wiring
Old 08-17-2007 | 02:28 PM
Default water wich wiring
looking to wire a water wich bildge switch so a warning light on the insturment panel will go on when the water level rises and turns the pumps on. Anybody have a wiring diagram to do this. Thanks in advance and happy boating! SC .
sschafee01@snet.net is offline
Old 08-17-2007 | 03:36 PM
jhiguy377's Avatar
i would just junction off the same wire that comes from your auto bilge switch; often there is a wire that goes to your dash that lights up your bilge switch. my scarab's lighted switch light comes on when the pump is operating. you coud put an extra light in the circuit to warn of water in the bilge. you could also put a separate auto switch in the bilge that would just activate the light. hope this helps, good luck. -jeff
jhiguy377 is offline
Old 08-17-2007 | 04:00 PM
Wally's Avatar
Were doomed!
If all you want is the switch to turn on a light when the blige turns on its real easy.....the bilge switch has two wires.....one goes to power the other to the bilge pump......take your light...one of the wires from the light goes to ground...the other (most likely a red wire) will hook up to the wire coming off the bilge switch that goes to the bilge pump. When the switch is triggered it sends power to the bilge and also tot he light....
-Wally
Wally is offline
boating37
05-27-2008 11:26 AM
MickeyBoy
Cigarette
1
02-07-2008 08:16 AM
B38
05-25-2007 11:07 AM
Steve H
02-12-2007 11:07 AM
Pat McPherson
17
09-04-2003 06:55 AM
