Replacing Hydrolic Lifters >
Old 08-19-2007 | 01:38 PM
gripit's Avatar
Default Replacing Hydrolic Lifters
Can you replace hydrolic lifters without changing the cam? My freind told we it would wipe the cam. Is this true?
gripit is offline
Old 08-19-2007 | 02:28 PM
Default lifter change
yes but do yourself a favour by borrowing a dial guage . whip your rocker covers and inlet manifold off,then loosen your rockers and take your pushrods out .set the dial guage up in the valley directly over the lifter and rotate the engine. check the lift on all the cam lobes this way , it should vary only a couple of thou. at least then you will know if the cam is rooted. its no good just replacing lifters if the cam is u/s. cheers tassie boy
tassie boy is offline
Old 08-19-2007 | 04:22 PM
gripit's Avatar
Tassey,
You lost me? Can you be more specific? Thanks
gripit is offline
Old 08-19-2007 | 04:49 PM
Registered User
He's telling you to check your lobe lift on the cam before you replace your lifters, to make sure that none of the lobes is out of spec. If intake is supposed to be .500 and exhaust .550 at the cam, this will tell you if it is. If you came up with an exhaust with only .500 than you need to replace the cam.
Why are you replacing your lifters?
the duke is offline
Old 08-20-2007 | 08:14 AM
gripit's Avatar
No, I'm not replacing them just have to keep tightening my rockers and was thinking down the line. I pretty much replaced the top end with new heads pushrods and rockers but didn't replace the lifters.
gripit is offline
Old 08-20-2007 | 09:02 AM
Knot 4 Me's Avatar
If you are continually having to tighten rocker arms, the cam is starting to go flat. I would not put new lifters on an old cam. Replace both the cam and the lifters at the same time.
Knot 4 Me is offline
Old 08-20-2007 | 10:23 AM
Steve_H
Thumbs down
ive got an old worn out cam and lifters you can have for free. hell i will even pay the shipping like last time
Old 08-20-2007 | 12:58 PM
gripit's Avatar
I hate that damn post office. Some sht-head must of thought it was a WMD. How could they lose something that big? Anyway, did you have a cam that went flat?
gripit is offline
FIVEPTOHH
Fountain
1
11-16-2006 09:08 PM
justinVIP
23
03-10-2005 10:26 PM
BAJA WILL
6
08-06-2003 11:10 AM
OPA
6
05-11-2003 11:33 PM
Bo Knows
04-02-2002 09:20 AM
