engine backfire >
engine backfire
engine backfire
Old 08-28-2007 | 11:46 AM
Default engine backfire
Had the boat out yesterday and the port engine started to lean pop out the carb under load. 1995 HP 500's carb motors, would be ok at idle and slight load (under 1500 rpm) but unable to bring it up higher. I am thinking my coil is going bad or a bad cap and rotor, has anybody had this happen before ? fuel pressure is good temp and oiil pressure is good, wires are MSD 8.5 reds and coils are the high vibration coils but are a bit older. Runs and starts grerat at idle but once it warms up and under load lean pop out the carb. no black smoke or rough idle at all.
laszlo01 is offline
Old 08-28-2007 | 12:22 PM
BY U BOY's Avatar
check your accelerator pump.
BY U BOY is offline
Old 08-28-2007 | 12:31 PM
Cam lobe or valve spring are also possible causes
Griff is offline
Old 08-29-2007 | 09:18 AM
Well i dont believe it to be carb related as idle and acceloration and light load is ok, it is speratic and not constant. feels more like electrical related.
laszlo01 is offline
Old 09-08-2007 | 04:02 PM
head gasket leak
Buddy OO is offline
Old 09-09-2007 | 09:49 PM
possibly timing, coil is also likely.
Probald meg kicserelni.
Good name Laszlo. Szervusz
PARADOX is offline
Old 09-09-2007 | 09:53 PM
Tinkerer's Avatar
Sounds like a valve or spring problem
Tinkerer is offline
Old 09-10-2007 | 02:38 AM
Battled the same problem on my Ski Centurian for over a month. Kept thinking it was an electrical problem. Fuel pressure good, float level good, accelerator pump good. Finally replaced coil....No bueno. Finally realized it was happening only under load with the 4 barrels open. I pulled the bowls and sure enough, one tiny air passage was plugged on the secondary side. A bit of chemtool and she runs good as new.
I would have bet big $$$ it was electrical, until I cleaned the carb.
Darrell.
DMOORE is offline
Old 09-10-2007 | 02:53 AM
dukenrock's Avatar
Had a similar issue with mine and it turned out to be a fuel seperator.
dukenrock is offline
Old 09-10-2007 | 06:05 AM
Biggus's Avatar
I've had the same symptoms and the end result was a bad rev limiter box.
Biggus is offline
speeddemon651
46
08-28-2016 01:33 PM
wieland77
6
06-17-2008 12:17 PM
madorno1
09-22-2007 11:05 PM
MitchStellin
17
05-17-2004 09:01 PM
BAD-HABIT
6
05-16-2003 08:35 AM
