-   -   What should Fuel Pressure be at WOT? (https://www.offshoreonly.com/forums/general-q/167987-what-should-fuel-pressure-wot.html)
Fast Algae 09-05-2007 02:24 PM
On a 7.4 mpi.
Seloc manual says 43 @ 1000 rpm w/ no mention of vacuum line.
If it is running WOT, should it be 43 pounds w/ vacuum line hooked up? (Would not try running without it hooked up.)
2000 7.4 mpi 310 horse.
Dr Ralphy 09-05-2007 11:26 PM
I have a pair of 99's and they run at 40-42 pounds for any rpms over 1200.
Run the same 40-42 at idle when the oil is cold and run 20-22 pounds at idle when the oil is warm.
speedreeder 09-06-2007 12:22 AM
Hey fast, Read your other post..
