BBC distributor upgrade >
Old 09-08-2007 | 03:53 PM
Full Force's Avatar
Originally Posted by Edward R. Cozzi
If you decide to keep the points, make certain that the shaft bushing is not worn allowing your dwell to fluctuate. Some old points distributors are pretty sloppy in this department.
I will check that, thanks.
Full Force is offline
Old 09-10-2007 | 07:47 AM
You set the points initially by gap. Get the timing and idle speed close to spec.
You'll need a dwell meter to set the points. About $25 at most auto parts stores. Hook it up as per instructions, then open the sliding door on the side of the distributor. There's an allen screw that sets the points gap and dwell. Tune it to specs. Now reset your timing, then your idle speed. Also check total timing if you've got a variable advance timing gun.
BTW, changing the dwell affects the timing so you have to set the dwell first.
BTW, I just pulled a completely corroded pickup and reluctor out of a 2 year old "hi performance" distributor this weekend. I wont say who the manufacturer was, but it rhymed with MSB. Makes points sound pretty good.
Gary
rdoactive is offline
Old 09-10-2007 | 09:14 AM
I don't remember ever seeing the old Delco points distributor with the window in a marine application, but in 21 years somebody could have changed it. I doubt if that automotive distributor was ever approved for marine use anyway, but I can be wrong about that too.
Do you have a Mallory or Prestolite distributor in that motor? You'll need to know to buy the correct points and condenser.
Edward R. Cozzi is offline
Old 09-10-2007 | 04:31 PM
Full Force's Avatar
Not sure what distributor it is, they used both them in 86 stock? they look factory to me.
Old 09-10-2007 | 05:51 PM
Take a picture of your distributor and I'll try to identify it for you.
Old 09-10-2007 | 06:00 PM
Full Force's Avatar
I will not be at the boat until Friday night, I planned to get the points first, maybe I will buy for both if they have them and return the ones I don't use.
Old 09-11-2007 | 09:01 AM
The Crane retro kit works very well for the old points type distributors. I have several friends with 80's model ski boats and have coverted 5 of them over to the Crane system. Easy start, no maintenance issues on all 5. The oldest one has been on the boat for 4 years.
cstraub is offline
Old 09-11-2007 | 04:33 PM
Full Force's Avatar
Lust look up crane? any part numbers?
Old 09-11-2007 | 05:40 PM
Should be a 3000-0226
cstraub is offline
Old 09-11-2007 | 09:10 PM
Full Force's Avatar
may have to look into that over winter!
