-   -   overheating and water in the bilge (https://www.offshoreonly.com/forums/general-q/168310-overheating-water-bilge.html)
fatdaddy 09-09-2007 09:34 PM
All this talk of ethanol and phase seperation, made me go out today to try and burn some old fuelo and my tech wants the tank low for winterization. Running the twin 496HO's hard, all is well but all of a sudden, an alarm. Port engine sputters and I shut them both down. The port side was running 220?+/-. Let them cool down to about 180 and fired up fine but in a few seconds the alarm was on again. Decided to limp back to the lift on the starboard only. Put her on the lift and gave it a few hrs. to cool down. Once cool, dropped back in the water. Fired up fine but no water exiting the exhaust and bilge came on. Opened hatch and water being dumped right into the bilge. I'm assuming a hose came loose or ripped but engine too hot to try and trace. I'm not going to be able to get back to it until next weekend. It's tight w/ twin 496HO's in a 33 Baja Outlaw. Any advice? Should I be able to repair/replace w/o pulling too much stuff off? TIA.
MOBILEMERCMAN 09-09-2007 09:41 PM
There are a bunch of hoses under the motor. You can only hope it's an easy reach. Good Luck
Jim
fatdaddy 09-09-2007 10:39 PM
Jim
They already had to pull the engines to do water pumps in the spring. Are you telling me I have to pull an engine b/c of a hose?
MOBILEMERCMAN 09-09-2007 10:45 PM
No, You'll have to see what happened. I hope not.
Jim
fatdaddy 09-10-2007 08:35 PM
Please, please, please, I have a bunch of relatives coming this weekend from Europe who want a ride. Moreover, it'll be a real pain to get it off the lift, down to the ramp and on the trailer on only one motor.
MOBILEMERCMAN 09-10-2007 08:42 PM
fatdaddy, when you lowered the boat was it rushing in before you started it? Does it only rush in while it's running? Do you have a flush attachment on the boat? Turn on hose does it leak? where?
Jim
BadDog 09-10-2007 08:43 PM
fatdaddy, they had to pull the engine for water pumps? You need to find a thinner mechanic!
fatdaddy 09-10-2007 09:20 PM
Jim
Yeah only when it's running. Thank God. And no flush attachment. ???
fatdaddy 09-10-2007 09:22 PM
I was thinking the same thing. I think he was thin before he met me. :cool: :rolleyes:
MOBILEMERCMAN 09-10-2007 09:44 PM
There are a bout a dozen clamps on the pressure side of raw water. You better go and check before weekend. Water pump is low on starboard side of engine, hose connect to bottom of exhaust manifold and up to cooler across back of motor. From the cooler hose leads down again to oil cooler and exhaust manifold than lower still to fuel cooler. Hose from fuel cooler leads to front of engine and up to heat exchanger.
Hope for an easy one. I will pray for you.
Jim
fatdaddy 09-10-2007 10:09 PM
Jim
:eek: Yes, please pray for me. I sincerely thank you for all of your input.
fatdaddy 09-11-2007 10:14 PM
Tech was supposed to go out today but the weather sucked so I'm still waiting and praying.
t500hps 09-12-2007 07:13 AM
It's a bit(h but you should be able to replace every water hose on the motor with it in the boat..... The last 2 years I've worked with some buddies doing ALL our own work (rebuilt 7 engines last winter) I've learned it may take awhile, but you can get it done.
Raylar 09-12-2007 09:55 AM
Fatdaddy:
Before you start replacing things, check the pressure relief valves on the water system. If you trace the small white and orange plastic lines down to the bottom of the motor you will end up at a brass valve assemblies(may be partially painted black by Merc). These are dump for winterization and pressure relief valves and we have seen them stick open and fill the bilge with the raw water from the pump very quickly and overheat the engine. Find these valves, start the engine quickly and see if they are dumping. Might be your problem.
Hope this helps.
Regards,
Ray @ Raylar
monstaaa 09-12-2007 06:15 PM
sounds like a main water line under the engine is off or as ray said the dump is stuck.
by thw way do you have sea strainers?
fatdaddy 09-12-2007 11:10 PM
No sea strainers.
fatdaddy 09-12-2007 11:11 PM
Originally Posted by Raylar (Post 2268569)
Fatdaddy:
Hope this helps.
Regards,
Ray @ Raylar
Thanks.
stevesxm 09-13-2007 08:46 AM
fat daddy...
not trying to be a cynic here but , while all the advice above is all good and correct in all respects, im a little mystified why you feel people hundreds of miles ( or maybe even 1000's of miles ) away can possibly know more than you just getting down in there and actually using your own two eyeballs to see where the water is actually coming from. granted... it might not be easy or pleasant but, in the end, its whats going to have to happen anyway.... everything else is just postponing the inevitable and wasting time.
fatdaddy 09-17-2007 09:02 PM
Originally Posted by stevesxm (Post 2269900)
fat daddy...
Are you kidding me? Not trying to be a cynic? What is it then that you are trying to be? Did you read my 1st post? Man, I can't even believe I have to respond to your ill fated advice. The boat is not at my residence but rather at my summer place, which I could not get to until the following weekend, which coincidently, is when I needed it up & running. Unfortunately, my arms aren't that long but if yours are I'm sure I can find some use for them. Again, I'm dumbfounded. This is a technical forum, which was created for members seeking information, which I rec'd and sincerely appreciated. :angry-smiley-038:
fatdaddy 09-17-2007 09:03 PM
The culprit, a torn hose, was fixed on Sat. a.m.. It ran perfectly again. Thanks to all, except one :D, who replied.
MOBILEMERCMAN 09-17-2007 09:38 PM
fatdaddy, sounds like good fortune prevailed.
Jim
fatdaddy 09-17-2007 11:21 PM
Yes sir, Jim, thank you again.
stevesxm 09-18-2007 11:31 AM
ah....... gee... sorry i missed the highly technical aspect of that first post... what was it now something like
" the alarms went off and the bilge filled up with water... anybody know whats wrong ? "
seems to me that my advice is the only one you actually followed....
sent someone down there who ( AMAZING , I KNOW ) actually FOUND a hole in the hose by LOOKING for it.
geeze. what an amazing and inovative diagnostic technique.
you should consider publishing that one.
PatriYacht 09-19-2007 09:13 AM
I tend to agree with stevesxm. While his answer may seem a little harsh, it is good advice. If you want to own a high perf boat, you have to learn to diagnose some of these problems yourself. Otherwise, some of these marine mechanics will take you to the cleaners with trumped up repair bills. And you might save time getting back on the water. Just my 2 cents.
