Blower on 500HP
Might be cheaper in the long run to replace head gaskets. You may be tempted to check cylinder walls while you are in there. Hard to beat the Cometic gasket for boost applications. You can also get Cometics in various thickness to change CR slightly.
Hey Steve, Shoot me all the info on the setup you have for sale. What all comes with it etc. [email protected]
Regards,
Steve
definately "on the edge" though....
Well, no doubt it would be a good idea to change the head gaskets..I did too..used the cometic .051 and I also went with the JE dished pistons...but it is not a have to....if the motor is strong now you would most likely be ok, for a short time...but one way or another, you will be freshening and changing head gaskets sooner or later.
As per Dustin @ Whipple the other small concern are the pistons. Rings postion more than the material. I didn't swap pistons, only head gaskets. Oh, and went with Dart Aluminum heads. Stock heads are cast and don't disipate the heat generated by the blower as well as aluminum. They also don't flow anywhere near as good.
Touch wood, my engine is stong and I have seen a 14 mph increase in a single 28' boat.
