Water temp rising and falling >
Old 09-13-2007 | 10:57 AM
bcfountain's Avatar
Registered User
the holes are 3/16 and drilled in a three-triangler patteren.i am running a ssmarine cross-over and this is the same t-stait mr gadgets talked about.i amrunning a blower on this motor also.temps are around 140-165 depending on water temp and how hard i run.also are your temp senders on the front of the motor?i ran mine at first on the rear/top of the manafold and the temp-gage always showed too hot....around 150-185.moved them to the front and temps read normal now.hope this helps
bcfountain is offline
Old 09-13-2007 | 12:40 PM
AZ Speed and Marine may have a high flow T-Stat. I believe I got a 120 high flow from them.
BadDog is offline
Old 09-13-2007 | 01:08 PM
Front top of manifold.
ghittner is offline
Old 09-13-2007 | 01:47 PM
Just spoke with Stainless Marine, and they say it needs the three holes. I'll post my results, thanks guys...
ghittner is offline
Old 09-13-2007 | 01:52 PM
ghittner is offline
Old 09-26-2007 | 12:30 PM
PROBLEM SOLVED! three holes and another new thermostat. I now run @ 165-170 consistently
ghittner is offline
86formula242ls
05-23-2006 07:52 PM
Pmpaint1
3
04-25-2005 11:10 AM
shawn
4
07-15-2003 09:57 PM
magnuman
3
07-08-2002 04:44 PM
Mrgoodwrench
3
03-25-2002 11:43 PM
