Identifing an HP500 >
Identifing an HP500
Identifing an HP500
Old 09-17-2007 | 06:54 PM
Pwrbt33's Avatar
Also look on the side of the engine block for the casting size in it. It will say 8.2 if its a 502 and 7.4 if its a 454.
Pwrbt33 is offline
Old 09-18-2007 | 03:33 AM
cuda's Avatar
I have a 1997 HP 500 that has a roller cam.
cuda is offline
Old 09-18-2007 | 08:05 AM
PatriYacht's Avatar
Originally Posted by Bajapred
Well, don't take this to the bank, but...Gen IV & V had flat tap & Gen VI had roller lifters...for the most part..but not always.
Gen 5 HP500's used Crane hyd. roller lifters with link bars between pairs. They're still listed in the Merc parts catalog for about 1700.00 a set. And about 1000.00 for the cam.
PatriYacht is offline
Old 09-21-2007 | 10:23 AM
apparently on the block it says "hi perf pass"
the serieal number is 6269315
it has 10051107 cast into the block
pullmytrigger is offline
Old 09-21-2007 | 10:30 AM
both numbers said "part number not found".......I think I did it right.
Old 09-21-2007 | 12:09 PM
OK, I went to stem to sterns web site, and looked up the serial number. First off, all of the Merc racing serial numbers started with 2 letters, then the numbers. The 6269315 comes up as a 370 TRS. meaning it's a 454. Hope it helps.
Darrell.
DMOORE is offline
Old 09-21-2007 | 02:54 PM
I went on www.mortec.com (cool site) with the 10051107 number came up as a 454 4 bolt mark 4 bowtie block.
Old 09-21-2007 | 02:56 PM
the guy called me back said he found the Merc mod number on the engine its D515839......comes up not found on the Bam site.....
Old 09-21-2007 | 03:32 PM
465 '90-'92 numbers are oc849992-of213244. 500's start at of213293 . My guess hes got 465. His # must start with OD not D
Jim
MOBILEMERCMAN is offline
Old 09-21-2007 | 04:39 PM
PatriYacht's Avatar
The 500 bulldog also fits those numbers. OC577253-OF745405
