-   -   speedo problem (https://www.offshoreonly.com/forums/general-q/169059-speedo-problem.html)
drew300zx 09-18-2007 11:10 PM
speedo problem
i have a bravo one outdrive and my speedo quit working, i followed the vac hose from the speedo back to the outdrive, i disconnected the vac hose from the outdrive and blew air into and it moved the speedo, has anyone had this problem before, could my outdrive be clogged or something? thanks for the help
Griff 09-18-2007 11:26 PM
The pick up hole is clogged on the drive. Happens all the time. The pickup hole is a little notch on the leading edge of the lower unit, about halfway between the cav plate and bullet. Just take a very small drill bit and twist it into the hole with your fingers to get the debris out.
drew300zx 09-19-2007 10:07 AM
i looked on the outdrive and cant find the pickup hole, does anyone have any pictures, thanks
US1 Fountain 09-19-2007 03:49 PM
The red arrow is the speedo pickup location. They usually get plugged with a peice of wood.
drew300zx 09-19-2007 05:17 PM
thanks for the help
AIR TIME 09-19-2007 10:07 PM
there worthless, get a gps then you will now your real speed:D which is always 3 to 5 mph slower than the speedo:rolleyes::D art
jswfl09 09-21-2007 12:34 PM
A problem I had with mine (Bravo I) is there is a small rubber hose in the drive that had blown apart. I had the boat pulled and was having a drive serivce/alignment done when they checked the hose. The tube from the speedo to the drive was fine and so was the pick-up but it was the small hose with the bend in it in the drive.
Mark Hulst 09-25-2007 08:58 PM
Best help I've had
Thanks! i've been looking for that hole seems forever. Plugged full of stuff.
