454 rebuild question >
Old 09-19-2007 | 08:24 PM
Default 454 rebuild question
Not looking for anything insane but want a more HP 400-450 range.
Had it rebuilt last year and a valve head broke off so back to the drawing bore.
I have a holley 950 mpi fuel injection, CMI sport lite headers, comp cam mild 262 xm etreme, stock crank and rods. seal power forged pistons 9.5:1 compression.
engine is a bore .030 atm with 781 big oval heads. I am considering the 496 option.
Any suggestion on what parts and what brand to use. the heads I am thinking manley extreme duty series. because i don't want valves breaking again. Crank bearing going with the clevite
Not a real motor head just want to have fun in my 2550 sx chaparal boat.
rcoon is offline
Old 09-20-2007 | 01:08 PM
Hi there.
I talked to Competetion products yesterday about htis.
Give the a call and discouse it.
The 496 option.
He told me that the 781 or 049´s will stop to work over 6000rpm on a stroker.
Matt-Sthlm is offline
Old 09-20-2007 | 01:21 PM
The 454-to-496 option is a great way to go with a boat. Torque is king, and the extra cubes will make a big difference. The heads you have are fine, just have them cleaned up a bit when you rebuild them. Remember use the torque, there is no need to spin that motor to 6000 RPM's. Prop the boat to 5400 max and it will live a very long life. Use good ARP fasteners and a cam that will give a big flat torque curve and enjoy. I've known a few people that have gone this route, and they could not be happier.
Darrell.
DMOORE is offline
Old 09-20-2007 | 05:02 PM
Thanks I talk to comp cams tech help. alot of info seems i need to get a cam for more flow
My current cam setup puts my rpm at 5k max. I like it to stay at 4800. It I get setup correctly how long can I run my engine at 4500+ RPM's
Quick verfication on fuel mixture. I beleive I should be at 11.8 to 12.2. Plan on putting a wide band O2 sensor so I know exact fuel mixture
What Manley valves do I use extreme or severe duty SS? Who's 496 kit should I use? Eagle, World?
for the Main bearing do I use the clevite H or p series?
rcoon is offline
Flamingo 42
4
11-13-2007 09:53 PM
speedchangesyou
14
05-05-2007 06:59 AM
MILD THUNDER
4
05-31-2005 05:55 AM
Stormrider
18
05-17-2005 10:38 PM
jw454
32
01-04-2004 09:01 AM
