Questions for the Engine mastermids??? >
Old 09-24-2007 | 01:01 AM
Need-the-Speed's Avatar
Xtreme Cooler Test Dumby
Question Questions for the Engine mastermids???
Scenerio:
Engines running great with full power. After a short time oil starts "oozing" out dipstick tube. Why?
Need-the-Speed is offline
Old 09-24-2007 | 04:27 AM
ROB FREEMAN's Avatar
blowby , or poor crank ventalation , check youre breathers or pcv valve see if operating properly
ROB FREEMAN is offline
Old 09-24-2007 | 05:48 AM
Vinny P's Avatar
I hate the winter!!
Possibly too much oil or bad windage. Maybe the crank is whipping it up and pushing it out the tube.
Vinny P is offline
Old 09-24-2007 | 08:42 AM
Motor has good compression. It was recently freshend up. The line checked. I will replace the valve.
Old 09-24-2007 | 08:44 AM
I changed oil and made sure level was correct. As far as the crank.....It's been running fine for several years.
Old 09-24-2007 | 03:54 PM
motor will can still have good cranking compression and still have enough blowby to push dipstick out , best bet is to run a leakdown and go from there , on my 598 my ring gap is a little loose and i get a little dipstick pressure / blowby / but its better loose than sticking a piston . rob
Old 09-24-2007 | 05:02 PM
Do you have vents coming off your valve covers????
Griff is offline
Old 09-24-2007 | 06:35 PM
Smitty's Avatar
is it a blower motor?
Smitty is offline
Old 09-24-2007 | 10:45 PM
Yes vents off the valve covers.
Yes it's a blower motor....merc. 575.
Old 09-25-2007 | 08:52 AM
Registered User
575 in a 24cs? That has got too be a screamer.
320es is offline
