How much more horsepower will I get >
Old 10-16-2007 | 07:40 AM
tomas_wallin's Avatar
Originally Posted by Smitty
Also thinking about a custom grind cam from RMBuilder/Bob
That's what I'd do!
tomas_wallin is offline
Old 10-16-2007 | 08:22 AM
Talking
Fastlane 40 See post #4
CNC-- 540 cubes is all that is in the budget !!! The next boat is going to have 572 blown engines that make at least 1200 each. This boat is not worth the effort.
Don't be hatin' on your Baja!
kennyo is offline
Old 10-16-2007 | 09:09 AM
Your 509's made 750hp at 8pounds boost which is about 500hp N/A which is a little light at only 1.0hp/cid but your torque at 850 is much higher indicating too little cam and a restrictive long runner intake. The more you can make N/A the more you will make boosted. I would think that your cam is a little small and your intake is a bit restrictive. All being equal 509 to 540 will give you 540N/A hp and then 8 pounds boost + 50%(270hp) to 810hp or +60HP.
I would open up the intake manifold and shorten the runners and go with a RM spec cam. If your new cam and ported intake gives you 1.15HP/cid then 540CID becomes x 1.15 = 620 HP and 8 pounds (+50% 8/16) adds 310hp to 930HP!! Even 600HP N/A (1.11HP/CID) + 6 pounds boost (6/16 + 37.5%) adds 225HP to 825HP which is where you want to be.
cobra marty is offline
Old 10-16-2007 | 07:13 PM
Smitty's Avatar
Thanks Marty. I am running a Crane 731 roller cam. Definitely looking for a custom grind cam. I would like to keep max boost at 6 psi.
Kennyo-- Don't worry brother. I decided to keep the old girl for a while longer, thats why the switch to 540's. The next ride will be a Top Gun with big power and 6's.
Smitty is offline
hammer_34
14
09-12-2004 09:09 PM
fountain fever27
8
03-13-2004 09:44 PM
Dock Holiday
3
10-10-2003 01:37 PM
Pat McPherson
Superboat
2
10-07-2003 11:37 AM
KNOT-RIGHT
44
06-11-2003 08:12 PM
