Anybody know a formula for this equation??? >
Old 10-06-2007 | 02:05 PM
CAPTAIN CHUCK's Avatar
Question Anybody know a formula for this equation???
Does anyone on here know how much weight an empty sealed 55 gallon drum will hold buoyancy wise? I am trying to figure out how many would be needed to make a floating dock that will need about a 5000 lb weight capacity. I also will be needing some drums. Hey Waterboy I remember seeing a post you made about have a bunch of them. Send me a PM if you can hook me up.
Thanks,
Chuck
CAPTAIN CHUCK is offline
Old 10-06-2007 | 02:30 PM
99fever27's Avatar
Assuming your using aluminum drums:
55 gallons converts to about 7.35 cubic feet. ( Gallons/7.48 )
Then using Archimedes Theory, we get the following info:
The internal volume of the cylinder is 7.35 / 15 * 14.7 = 7.2 cu ft
The cylinder is made of 50 lb of aluminium, (which has a density of 170 lb/cu ft).
The aluminium therefore has a volume of 50 / 170 = 0.29 cu ft, so the total volume is 7.2 + 0.29 = 7.49 cu ft.
The density of fresh water is 62.4 lb/cu ft, giving 7.49 x 62.4 = 467.4 lb
Air has a density of 0.075 lb/cu ft.
The air in a full cylinder weighs 0.075 x 7.35 cu ft = 0.6 lb.
The cylinder when full has a buoyancy of 467.4 lb - 50 lb = 417.4 lb
12 Drums
99fever27 is offline
Old 10-06-2007 | 02:37 PM
Thank you sir for that info. I actually planned on using the plastic drums because I think they will last longer and be a bit more puncture proof. I imagine the overall capacity would be a little higher due to less weight of the plastic vs. the aluminum. Correct?
Old 10-06-2007 | 03:47 PM
When we built our dock at our cottage I used steel drums and had them filled with urethane foam. I thought if a puncture were to happen it would't be a problem . It would work great with plastic drums too . You will loose a little lifting capacity by filling the drums . Don't know how much . Just weigh the drum before and after and subtract the difference .I used the company that spray foams my houses so I never got billed but I can't see it costing more than 50 bucks a drum .
Paul
1bagger is offline
Old 10-06-2007 | 03:57 PM
fever is correct... including the part about the weight of the barrel. it really doesn't matter what material the barrel is... just weigh it . the bouyancy will be the interior volume in cubic ft x 64 minus that weight.... just as he says.
stevesxm is offline
Old 10-06-2007 | 04:17 PM
Thanks guys. I am just going to go with 12 and that should be enough. I appreciate the help.
FormulaM2Formula
03-20-2006 08:52 PM
durbin3
0
06-13-2005 08:02 PM
39NAS-T
04-27-2005 07:10 PM
Toffen
07-28-2003 02:28 PM
