-   -   retrotek??? anyone know? (https://www.offshoreonly.com/forums/general-q/170561-retrotek-anyone-know.html)
Mr Gadgets 10-10-2007 12:53 PM
rdoactive,
I am using the MSII on my 565" motor. Took a bit of a learnig curve but it is working quite nicely. I did modify the driver circuits for the Low Z injectors, to a more reliable setup. The Megasquirt works much better than the Culter system I ran for years!!
Cost is low, but then you have to figure in the hardware that I already had.
D*ck
ls1nova 12-19-2007 08:32 PM
That system has no real advantage over a carb. You are still running a "wet" manifold and not taking advantage of the fuel injectors atomizing cababilities. A multiport setup is the better way to go without question.
Frank
jeff1000man 12-19-2007 08:41 PM
Why complicate the issue?
ls1nova 12-19-2007 08:43 PM
What issue? Or are you saying to just run a carb and be done with it?
Frank
jeff1000man 12-19-2007 09:00 PM
Frank
Keep it simple. I just don't see the benefit in complicating things by using that set up except for the fact that it looks cool. It's really not that different in functionality from a holley system out of a Summit catalog as far as I can tell.
I don't see it making any more power than a carburator, when used in a boat.
