do i need to run a drive with reverse rotation
I am building a 30 ft scarab with 2 454 motors trying to find out if i need a reverse rotation drive. If i do can i have a drive that is standard rotation reversed, also if i put on team g intakes with holley carbs will this screw up the way a otherwise stock motor runs or should i run stock intakes and carbs
please help thanks
please help thanks
so you say i should run one left rotating lower does it matter what side i install it on
Also any one ever hear of a alpha drive being built to bravo specs if so what does that mean and how can i tell what gears or in a drive. i think i will need to match gear ratio i believe if im wrong please let me know thank you all i realy appreciate the help
