Piston Failure Modes 101 >
Old 10-14-2007 | 10:10 AM
Rage's Avatar
Default Piston Failure Modes 101
What are the piston design variables versus piston failure modes for hypereutectic pistons and the Merc 496 pistons in particular?
I have a Merc 496. The slock hypereutectic cast aluminum pistons are nortorious for failures with certain engine mods for increased hp. I have read herein about these pistons "melting", "shattering", "disintigrating" do to "detonation", "heat soak" because the pistons are designed "with hypereutectic aluminum","are cast and not forged", "are brittle", " top ring is too close to the top of the piston", " the top ring land is too thin", "the piston intake valve relief creates a weak spot over the top ring", "the top ring gap is too narrow". Elsewhere "rpm limits" are also mentioned.
1.) With detonation what is the failure mode(s) of the HU piston?
2.) With high hp high engine combustion chamber temperatures what is the failure mode(s) of the HU piston?
3.) What is the most common failure mode of the HU pistons?
4.) When selecting a forged piston replacement for a Merc 496 what features/variables should be changed/specified as hp of the engine goes up? IE a 600 hp engine, 700 hp engine. 800 hp engine, 900 hp engine for example?
Rage is offline
live wire
03-29-2008 02:31 PM
restabr
09-05-2007 06:03 PM
Quest for Speed
23
12-07-2003 06:05 PM
Magicfloat
06-06-2003 07:54 PM
