Carb issue?
Guys,
I was fogging my HP500s the other day for winterization. I noticed, at idle, fuel dripping from the primary venturies. Is this a sign that the carbs need rebuilt, a gasket replaced? The boat does smell rich at idle wehn out running it... Regards, Z |
Blown power valve.
Originally Posted by razor1115
(Post 2324534)
Guys,
Originally Posted by rdoactive
(Post 2325284)
Blown power valve.
It might not be the PV. It could be a needle seat adjustment. Also, it could be nothing.
The angle of the boat is probably different on the trailer, than in the water. The forward angle on the trailer will fill up the primary fuel bowls higher and cause them to drip into the carb at idle. Check it with the boat in the water in the Spring. |
Originally Posted by Griff
(Post 2325668)
And if it's still doing it in the spring, in the water, perhaps the floats need adjustment from all the wave pounding...
(Post 2325668)
| All times are GMT -5. The time now is 02:59 PM. |
