need Help with Cam degreeing - What am I doing wrong? >
Old 11-05-2007 | 09:24 PM
GNJ's Avatar
GNJ
Default need Help with Cam degreeing - What am I doing wrong?
I degreed both my 502's and set the ICL at 106*. That I'm pretty sure of.
I am using ZZ502 cams and changed my exhausts to dump the water farther down the exhaust because i was getting reversion. Cam info:
.527/.544 110* LSA
Duration 224*/234* @.050
My degree wheel seems to have an indicating range of EVC which goes from 20* to 60*. At 106* ICL, the EVC on the wheel shows 74* ATDC.
When I plug the cam info into the desk top dyno, it says the EVC should be 3* ATDC. Why are these numbers so far off from each other? Am I missing something here?
GNJ is offline
Old 11-05-2007 | 09:52 PM
Vinny P's Avatar
I hate the winter!!
This link from Comp Cams explains the degreeing procedure well. On a side note, although your duration is not that radical, that 110* lobe seperation may be too tight for wet exhaust not to revert.
Vinny P is offline
Old 11-07-2007 | 08:18 PM
GPM
Your cam card numbers are probably at .050 lift and your desk top dyno is probably at .0 lift.
GPM is offline
Old 11-07-2007 | 09:07 PM
GNJ's Avatar
GNJ
Thumbs up
AHHHH! Thats right! Thanks GPM. I never received a cam card on the ZZ502 cams, but I did make the mistake and put the duration #'s in the desk top dyno based on .050.
Do you or anyone know how to convert duration numbers @
.050 to seat to seat?
GNJ is offline
Old 11-07-2007 | 09:19 PM
GPM
The numbers would change by ramp speed, you could check it in the motor with a dial indicater and a degree wheel.
GPM is offline
blue thunder
12
02-04-2007 04:13 PM
Game On
07-19-2006 08:49 PM
1BIGJIM
13
06-16-2006 01:29 PM
KEPP
0
05-19-2005 02:39 PM
timucin
8
11-24-2003 12:08 AM
