Best Oil Temp Sensor Mounting Location
Registered User
One really important thing to remeber- if you're screwing a sending unit into a tee, adapter or other in-line place to measure oil temp, be sure it doesn't restrict oil flow. i've seen long senders that would cut flow in half- which is bad.
Also, no sharp-angle fittings. Use sweeping 90's and 45's if necessary. Go up one hose size, then adapt down where they go into the engine, adapters, etc.
Otherwise the opposite would be true?
The remote filter is the easiest. The place it belongs is after the cooler, before it goes back into the engine.
You need to know temp of oil to the bearing. Thats the purpose of knowing oil temp. To assure proper lubrication to the bearing.
Relocating the sender from the T off the remote filter to the engine port above the filter pad did no good ...maybe as stated the probe was not in a good stream of oil ...
Then I relocated the sender to the oil thermostat .. Drilled and taped a cap over the spare port ..the probe is well into the main body of the housing ..measures the oil comming from the filter ..( lock..filter ....thermostat ...cooler ...motor)...
works ... ran 180-190 yesterday at 3200 cruise ... Now the question is did they send me 190* stats or 212's ?
Pulled the Thermostats and they are the correct ones ..212* ......Temps still wont get up over 190 and I am getting milkshake on the bottoms of the Valve cover breathers ....
Just a note I am still running one motor with 142* stat and no stat in the other ...both motors run the same 140-150 .. cept I did notice in the motor without the thermostat the oil temp is alot slower to come up at all and is generally lower .. So i am thinking the motor with the thermostat seems to get the motor a more even temp overall ...but still have low oil temps ........m
