GEN VI HEADS-DART BLOCK compatible??? >
Old 11-26-2007 | 07:34 PM
racinfever's Avatar
Never ever never use gen 5 or 6 heads on a gen 4 style block, But you can use GEN 4 style heads on a gen 4 ,5 or 6 block useing felpro 1037 for sml bore {454} or 1047 larger bore 502 - 540 dart blocks are gen 4 style all after market cyl. heads gen 4 style. hope this helps !!
racinfever is offline
Old 11-26-2007 | 11:07 PM
Fancy book lernin not wot its all made out to be..can't argue with first had $$ loss as a burning reminder. Thanks for the correction Biggus
nwimbush is offline
Old 12-02-2007 | 10:57 AM
I found this review online that explains the coolant passage differences between Gen IV/V/VI that might help with this issue..http://reviews.ebay.com/Big-Block-Ch...00000001563647
Here is an excerpt.
"Coolant Routing Mk IV/Gen 5/Gen 6
There are two different ways that coolant can be routed through the engine: series flow and parallel flow. Both ways work just fine. There may be a slight preference for parallel flow, but it is not a big deal. Series flow has the water exiting the water pump, flowing through the block to the rear, it then transfers through the head gasket and into the cylinder head through two large passages on each cylinder bank at the rear of the block. The coolant then travels from the rear of the head, forward to the front of the head, into the intake manifold water passage and out past the thermostat and thermostat housing. The water cools the block first, then it cools the head. The coldest water (coming out of the water pump) is directly below the hottest water (having already picked up the heat of the block and the head) as the hot water transfers into the intake manifold. By contrast, parallel flow has the water exiting from the water pump into the block, where a portion "geysers" up into the head between the first and second cylinder, another portion "geysers" up to the head between the second and third cylinders, another portion geysers up to the head between the third and fourth cylinder, and the remainder transfers to the head at the rear of the block. The coolant temperature inside the engine is more even that way. The differences in coolant routing is having (or not having) the three additional coolant transfer holes in each block deck, and three matching holes in the head gasket. The heads have passages for either system, and are not different based on coolant flow.
Be aware that gaskets that DO have the three extra holes between the cylinders often have restricted coolant flow at the rear--instead of having two large coolant transfer holes at the rear, there is only one, and it's the smaller of the two holes that remains. This is important because if you use a parallel flow head gasket on a series flow block, you can have massive overheating and there's NOTHING that will cure the problem except to replace the head gaskets with ones that don't restrict flow at the rear of the block, or to drill the block decks to allow the coolant to flow into the head between the cylinders. Here's why they can overheat: A series-flow block doesn't have the openings between the cylinders, no coolant can flow up to the head there. The gasket may only have the single, smaller opening at the rear, so the amount of water that gets through that opening is greatly reduced from what the block designers intended. The result is that the coolant flow through the engine is only a fraction of what is needed.
Most, but NOT all Mk IV engines are Series Flow. ALL Gen 5 and Gen 6 engines are Parallel Flow. A series flow block can be converted to parallel flow by drilling 3 holes in each deck surface, and then use parallel flow head gaskets. You can use the parallel flow gaskets as templates for locating the additional holes. It's really easy: Put the parallel flow gaskets on the block, mark the location and size of the three extra holes. Remove the gasket. Grab a 1/2" drill and a drill bit of the correct size, and pop the extra holes in the block. There is NO modification needed on the head castings. Some blocks have one of the holes already, but it needs to be ground oblong to properly match the gasket. Again, very easy with a hand held die grinder and rotary file.
nwimbush is offline
Monkey Spanker
13
12-31-2005 04:34 PM
baja226s
4
11-16-2005 06:58 PM
QUIKDECISION
2
04-25-2005 09:20 PM
klmken
2
08-01-2003 09:25 PM
blown formula
3
01-08-2003 02:28 PM
