Stereo guys, are these current draws in line? >
Old 11-25-2007 | 09:20 PM
The fuse for the amp will act the same as the bildge pump. However, the amp is a non critical load, and there should be no reason that it would need power with the switch off.
If you read auto instructions, of course they don't mention the battery disconnect. They don't exist in cars. If they did exist, the manual would also say wire after the switch.
Joe92GT is offline
Old 11-25-2007 | 11:01 PM
Outdrive1's Avatar
Masher touches my
Originally Posted by US1 Fountain
Do the in-line fuses on each of the amps power act as a disconnect? Be the same concept as the radio memory and bilge pump leads. Just outta curiosty. Will go the switch though, not a hard install.
Was going by the instructions, of direct wiring to the battery with the fuses right at the battery. But these are automotive amps, not the marine version. Possibly the reason of no mention of a disconnect??
Thanks again!
You could put circuit breakers in instead of the inline fuses and use them as a switch instead of wiring in a switch.
Outdrive1 is offline
Old 06-01-2008 | 05:48 PM
Im having a hard time finding a disconnect like whats mentioned here. I found one at Oreillys that has a red key that you insert to turn the switch on and off. But it doesnt say anything on the pkg about how much load the switch can handle. Should i put it on the positive cable from the amp a few inches away from the battery?
waterboy222 is offline
Old 06-01-2008 | 06:17 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I ended up hooking the (+) leads from the 2 amps to an 80A solenoid between the amps and battery that would disconnect my amps from power as soon as my radio was turned off. The amps turn on wire is used to trigger the solenoid. All automatic with nothing to switch on/off.
US1 Fountain is offline
Old 06-02-2008 | 06:46 AM
the 250/1 amp is pulling 32mA
the 300/4 amp is drawing 2.6mA
Why such a difference? Enough to drain a battery in 1 week?
An average deep cycle with 140 minute reserve capacity can maintain that load for about 70 days, not 7.
NightHawk is offline
Old 06-05-2008 | 03:56 PM
What guage wire do you recommend for a 30ft run?
Rock Star is offline
Old 06-05-2008 | 04:14 PM
BDiggity's Avatar
Depends on the draw, but i always use 0/00g cause its relatively cheap compared to all the other equipment.
here is a chart to help
http://www.the12volt.com/info/recwirsz.asp
BDiggity is offline
hp500efi
Sonic
5
04-05-2007 09:21 PM
TEAMBAJA
Baja
59
05-04-2006 08:22 AM
OldSchool
02-07-2006 07:05 PM
Boomer35
02-03-2006 11:28 AM
