Can a 454 put out 650hp on 9.5:1 compression? >
Old 12-11-2007 | 10:58 PM
With really good head work and the right cam you can get there, but that is a lot to expect from an NA engine.
I would rather have one with a small blower and smaller cam so that the valve train would last a little longer.
Little young in this business, What do you guys think about my opinion?
I think you pretty much nailed it. Why put a GORILLA camshaft in there and spin it to the moon unless you have to. Those instances are rare, like in a limited class of racing. You can only use certain parts and do certain things, so you do what you have to in order to make the most power you can. That is a race motor that may or may not stay together. That is not what you want in the family cruiser.
I'm of the opinion to build more cubic inches and keep the rpms down by putting together a package that works and makes your target horsepower with as little camshaft as possible. If you can't make the number that way, then give it some artificial atmosphere (that's a blower for those who don't understand)
Young Performance is offline
Old 12-11-2007 | 11:43 PM
I do most of my work right now with 4.375 cranks. I go with displacement first and work backwards depending on the what we are looking for.
Big power from large displacement is not automatic, but it is a lot easier.
A problem I have been coming up with in my calculations is keeping compresion down. How practical is it to open up the combustion chamber? Most open chamber heads are around 188-199cc. How big can you make the chamber on a normale iron or aluminum head? Is using a dished piston the most common way to go on a high boost engine, or are other things done?
I can get into the mid8's on a carb without geting crazy on the cam, but at that point it is time to start with blowers. I am contemplating my next experiments and want to start getting into 10-1271's.
jeff1000man is offline
Old 12-12-2007 | 06:45 AM
You can make the power, but will the engine idle? If you put enough lift and duration, a lot of things are possible, but what about the center line. Are you going to have a reversion problem.
I have a little 468 that I built out of left over stuff in my shop that makes 9.5:1 that I use for experiments. I put a .560, 248 solid flat tappet cam in that I want to try out in a couple weeks when my Dyno gets here. Has ported 049 iron oval heads on it. I'll let you know what it makes, but I think it is going to be low 5's
The engines idle like kittens, shift without stalling, and just plain haul azz.
mrhorsepower1 is offline
Old 12-12-2007 | 06:48 AM
I hope you wrote that down Dean
I can't believe I've been doing it wrong all these years
I should have paid better attention in school
Eddie, Believe me I did.
Hope alls well and have a Happy Holiday bro!
Old 12-12-2007 | 08:28 AM
What is the exhaust system on these engines? The original Merc 420 cast iron exhaust rusted and leaked. If it was converted to the standard Gil wet exhaust, this would be another reason that the "in the boat" HP is more likely close to 500HP.
Another angle you might look at is performance. If this 38' boat still has the TRS drives, they would be on the edge at 650 HP....this Scarab would probably weigh 11,000+ lbs with crew and fuel.
Maybe a top speed in the high 60's to 70 MPH? My 30' Scarab with TRS's only ran about 70-72 MPH with 500 HP in 1988....pre-GPS so even that is suspect
BenPerfected is offline
Old 12-12-2007 | 08:59 AM
Everything is going great. Couldn't ask for more. Hope you guys are all well and you to have a Happy Holiday.
Old 12-12-2007 | 12:00 PM
I had 650 in my 377. I actually had it to 74 once with the TRS's in it and it might have had a little more with the right props. THat boat was a whale. It weighed 11700 on the trailer with 0 gas in it at the truck stop.
Old 12-12-2007 | 05:02 PM
??? Learn something new every day......
whats the matter????
Dave F is offline
Old 12-13-2007 | 10:40 AM
Rookie's Avatar
?? Is it the lift on solid roller cams that are hard on valve trains, or duration or cambination of the 2. You guys are making me nervous of the cams I just installed.
Rookie is offline
Old 12-13-2007 | 10:45 AM
Combination of everything actually. Solid roller cams need high spring pressure to operate, big springs close valves faster and harder, Solid rollers also open and close faster by design, this is why the lifters are so damn expensive by design.
Thye are great though. I use them at every oportunity. I don;t see why you can't go 200 hours or so between having heads re worked or checked, if they are set up right initially.
Some of these other guys can probably give you some better insight.
MattBMiller
3
12-05-2006 03:24 PM
alcor
02-27-2006 05:54 AM
mtgbiker
22
08-08-2005 09:37 AM
FunHome
3
06-15-2004 01:25 PM
Holy Smokes
5
03-30-2004 07:28 PM
