454 magnum problems help please >
Old 05-28-2008 | 07:45 PM
  #111
Griff,
I had a family problem and had to put the boat on the back burner for a while but now everything has worked itself out. I have started the boat on the hose and I am nervous to drop her in the water and put it under load. When it runs on the hose it sounds great, no ticking or anything. What would be the worse case scenario if the valves are not right?
alamo28 is offline
Old 05-29-2008 | 03:55 AM
  #112
Originally Posted by alamo28
Griff,
You'll break something
Seriously, I think you'll be fine. Just take it easy while you're testing it out and work your way up in rpm gradually with short WOT burst at first and then longer ones. If it idles smooth and there is no ticking, you should be fine. If you here a little backfire under load,either throught he carb or the exhaust, you probably have a valve that is a little too tight. I really think you should be fine though.
Griff is offline
Old 05-29-2008 | 10:36 AM
  #113
Thanks Griff,
I am going to drop her in the water this weekend and see what happens. Thanks for all of your help
alamo28 is offline
Old 05-30-2008 | 12:18 PM
  #114
Cannot believe you have waited this long to get her wet. Good luck sound like you will be fine. Take it easy don't get crazy this weekend, come back home change oil and filters, while changing oil look for water in oil, and metal flakes. Check your outdrives for water before you go, check outdrives when you get back. If gas is old put some additives in to freshen it up, and some octane boost additives. You may need to adjust your carbs, thats another thread you may write after this weekend. If the motor don't run just right don't be hard headed and think running the crap out of them will fix anything. See if someone can tell you how to set your carbs on the water. I know how but I would rather an expert tell you. Very important not to lean them out to much. Take a inferred thermometer with you don't trust gauges and alarms the first time out. Take it slow and easy with hatch open, watch the motors for leaks, oil, water,gas.
Just remember FEELS LIKE THE FIRST TIME.
B one is offline
Old 05-30-2008 | 02:52 PM
  #115
Skip the octane booster. Anything you get at the auto store is worthless. You would be better off to put some 91-93 octane fuel in it. try to mix in 50/50 with whats in the tank.
About the only thing you can adjust on the carb on the water is idle mixture and float level. You can change jets, but it I wouldn't do it without being at a dock.
Griff is offline
Old 06-02-2008 | 03:42 PM
  #116
Default did it float
well what are you waiting for tell us the good news.
B one is offline
Old 01-06-2009 | 08:36 PM
  #117
I have put distributors in at 90 deg off norm 5-6 teeth? to clear fuel pressure regs on efi's with the holley stealth ram setup and to make the wiring not so cramped up, if you phase your rotor close its going to fire, get your timing light out and use it anything from -10 to +40 will idle set max timing at 32-36 deg this will get you so f 'n close its stupid.
you could put a distibutor in way the f off and as long as you phase the rotor whitch will require a long scewdriver to adjust the oil pump shaft accordingly it will run trouble free, c'mon its a machine it has no f 'n idea where it's at, it's location or weather it's two teeth off. ten degrees at idle is ten degrees at idle upside down or inside out,
I hope I helped us all !!!!!!!!!!!!!!!
500hpscorpion is offline
Old 01-06-2009 | 10:16 PM
  #118
This thread is over a year old and I still don't know if his boat ever ran.
alamo28
Last Activity: 05-29-2008 10:35 AM
Griff is offline
Old 01-08-2009 | 01:19 PM
  #119
Griff, LMFAO. I concur.
rednourdj is offline
Old 01-09-2009 | 06:42 PM
  #120
This thread gave me a headach. It did however make me once again appreciate my Father. Who I lost 9 years ago to a Heart Atack. I take a lot of things for granted like how he tought me to set ignition timing and set valve lash at the age of 14. It may not have been on a BBC but a I4, V6, V8, its the same principal.
jeffswav is offline
