Low Oil Temps ... >
Low Oil Temps ...
Low Oil Temps ...
Old 01-01-2008 | 12:54 PM
Velocity Vector's Avatar
Crazy Energy
Originally Posted by offthefront
The first test bypassed the oil around the cooler ...no oil thru the cooler ... Second test bypassed the water around the cooler ....but not totally ..just a shunt around the cooler with 1.25" water line intact ....it was a 1" bypas with a 3/4" gate valve ... Since then I bypassed the other motor with a 1.25" line with a 1.25" ball Valve ....better results but not there yet ... next will be the 1.25" bypass with ball valves in the Bypass AND the water Supply leaving the Oil cooler so I can Throttle back water thru the cooler .... I think that might do it ...m
I see now, OK. That should do it, let us know Thanks K.C,
Velocity Vector is offline
Mr Gadgets
58
12-21-2007 11:54 AM
BadDog
2
05-15-2007 01:44 AM
BAD-HABIT
9
10-28-2005 07:58 PM
boatman747
16
10-15-2005 03:21 PM
team Tickfaw
8
03-29-2005 09:45 AM
