upgrading a 509 >
upgrading a 509
upgrading a 509
Old 01-02-2008 | 06:39 PM
with a blower i dont think you need a high dollar, high flowing heads, you just need an affordable aluminum to help with detonation
5050 is offline
Old 01-02-2008 | 07:16 PM
Good heads make power , I have a buddy with a 454 4.250 crank making it a 496, 250 blower dart 360 aluminum heads making 699hp on the dyno:cool.-smiley-027:
formula 382 sr-1 is offline
Old 01-02-2008 | 11:41 PM
racinfever's Avatar
The Canfield cyl head is a great head for the money , about 2500.00 a pair complete with siv dudy valves tit retainers & springs Beware not all complete heads are sold with good marine grade parts . Make sure that your short tail pipes are not causing water injest. or more cam will make things worst.
racinfever is offline
Old 01-03-2008 | 12:32 PM
Originally Posted by Griff
Yes, its a roller cam. As far as heads, I'm no expert. I have read the merlins really are not very good w/o some porting work. You get what you pay for. I would probably go with some AFR's. The Edlebrock Marine heads are pretty decent too and a good bang for the buck. The are what merc uses on the 525EFI. A friend made about 800hp with them on a whippled engine.
Are you really saying that Merc uses Edelbrock heads on factory built 525EFI's?
Alex is offline
Old 01-03-2008 | 02:25 PM
Yes, that is what is on 525EFI's. Not sure how or if they are modified.
http://www.offshoreonly.com/forums/s...ight=edlebrock
Griff is offline
Old 01-03-2008 | 02:32 PM
racinfever's Avatar
mercury used Edelbrock on the 525efi ,they work well if you only run your motor to 5200 rpm.
Old 01-03-2008 | 03:16 PM
What limits the rpm? Runner size, flow numbers ...? And what about the oval ports, even lower in rpm?
Alex is offline
Old 01-03-2008 | 03:39 PM
Originally Posted by hoozeyurdaddy
I'm looking for suggestions on upgrading a 509, It's going to need a bore due to minor watermarks in the cyl's, It's running a 256 blower w/superchiller and 6psi boost, 2 750 holley's built by nickerson, 525sc cam, flat tappet w/roller rockers, 502 bowtie heads rec. port, thinking about alum. heads and cam upgrade, but water ingestions seems to be a problem, It was disassembled for a blown head gasket between #5&7.
what is a good alum. head that will perform well but not break the bank, this boat gets run about 10 hours a year.
Larry
you probably already know this but you are right as far as buying an aluminum head on a budget, so you wont have to worry about detonation. there is gonna be heads that flow more, that are more expensive which would be the right idea for nat. aspirated motor. with a blower you just create more boost to get your flow so dont waste your money on an overly expensive set of heads just make sure you get high quality valves, springs ect. just my opinion
i would suggest edelbrock or procomp
5050 is offline
Old 01-07-2008 | 11:55 AM
Smitty's Avatar
ARP makes stud kits for just about everything.
Smitty is offline
itbs
22
01-02-2008 05:02 PM
daveintexas
23
01-14-2007 10:05 PM
plumbers crack
12
01-08-2004 09:20 PM
Fast Forward
Powerquest
6
07-22-2003 11:06 PM
Andy Buzz
7
02-25-2003 06:47 PM
