What block is this? V12?
1 Attachment(s)
Weird looking,Anybody know what it is?
[YOUTUBE]http://uk.youtube.com/watch?v=0LCaRqQ8Qf8[/YOUTUBE] |
W12
VW/Audi/Porsche, can't remember which.
4 rods per crank journal?
Audi.
It's basically 2 V-6 engines using a common crankshaft and more or less siamesed into each other. The left-side outer row of cylinders is a 60-degree V-6 referenced to the right side inner row. It has a 6-throw crank with offsets on each throw journal. |
I did some googleing , didn't find much.Looks like a Winberg crank for a merc v6 outboard,Anymore info? Looks intriguing:D
I dont think its anything at all.Looks like a back yard mechanic with some walmarts tools trying to look like someone important.:D I had an engine guy just like this once,turned out to be a TOOL saleman.:D:D:D
Nordic95 |
It's definitely the Audi. I've seen the engine disassembled.
It is an Audi/ V.W. motor. It is used in the V.W. Phaeton here in the states.
2 Attachment(s)
Rob,
That is a clip from a video from Matsuura. The particular segment is the production of a Bugatti Veyron W16 (16 cylinder)block manufactured at the VW factory. The block is machined from a solid billet core. The entire video of this process can be viewed here: http://www.youtube.com/watch?v=GU32Q6QXtWQ It appears during the initial machining process the block is a W12, however at the 7:00 minute mark of the video you can clearly see the final stages begin where the additional 2 hole per side are final machined. Also it is evident the block is not an Audi/WV piece by the differences in the span of the valley in the photos below. The assembly process of the Veyron W16 engine can be viewed here: http://www.youtube.com/watch?v=Q34xI...eature=related A video of the Bugatti Veyron claiming “Fastest road car in the world” @ 253 MPH/407 K http://www.youtube.com/watch?v=lTNlZ...eature=related Audi W12 block |
Originally Posted by rmbuilder
(Post 2395730)
Rob,
The assembly process of the Veyron W16 engine can be viewed here: http://www.youtube.com/watch?v=Q34xI...eature=related Look at 1.53 It looks to be a forge crank. not billet. Bob look at 4.53 the block looks cast in the video. Its weird the macing the back 2 cylinders at a diff time ,maybe its the fixture? |
| All times are GMT -5. The time now is 04:14 AM. |
