Scat cranks
Old 01-20-2008 | 08:00 PM
Registered User
Default Scat cranks
Does anyone have hands-on experience with the Scat crank? I have a pal who wants to do some beer-budget mods to his 454's. For $575, they look tough to beat. Company appears to be reputable and based here in the US. I understand that they're an imported forging but the machine work is done here.
Looking at the stock rod length 4.250 piece. Maybe 600-625 hp.
Downsides?
Chris Sunkin is offline
Old 01-20-2008 | 09:20 PM
I have heard of some guys using them with good results. I had a Eagle Crank in my old 540, wasnt true out of the box. Sorry cant be of more help.
MILD THUNDER is offline
Old 01-20-2008 | 09:39 PM
For the money Scat has a nice product. Compared to the other imports, they have the best machine work.
TxHawk is offline
Old 01-20-2008 | 10:37 PM
Elite Marine's Avatar
Call Bill at Ateco. He is a Scat dealer and has been for years. He uses Scat unless a customers specifies something else and he has been building big power for years. He might be able to help your buddy out too. He sells rotating assemblies for a very decent prices.
Ateco Engine and Dyno Shop (847)623-2737
Kirk
Elite Marine is offline
Old 01-20-2008 | 11:18 PM
Chris,
I have used more than a few Scat cranks and could not be happier with them. I have made upwards of 1000 hp with one with no issues. I wouldn't recommend it, but it is what the customer wanted. The engine started at around 750hp and grew from there. I usually use them in my 650's and they work great. I am not at all happy with the Eagles. The journels are all over the place. They seem to be Scat's competition and to me it is no comparison. Tell your buddy not to hesitate using a Scat crank to make 625 hp.
Eddie.
Young Performance is offline
Old 01-21-2008 | 07:48 AM
Registered User
Eddie,
In looking at their catalog, I see two rod lengths listed. Is one for short deck and the other tall or do they have a high pin on the long rod length? If so, the longer rod is attractive but do you have piston rock issues with such a short slug?
Old 01-21-2008 | 10:04 AM
Chris,
If yo are going with a 4.25 stroke crank, then use the .250 long rod(6.385) and use a piston with a 1.27 comp. height. I will not go any lower than a comp height of 1.25. As long as the piston you choose doesn't have an exceptionally short skirt, you will not have a problem with excessive piston rock. If it were going in a tall deck, than I would use a 6.800 rod.
Eddie
Old 01-21-2008 | 07:16 PM
If you buy a scat rotating assembly, call and check part no's.
Their catalog has been wrong in the past. I know first hand. I'm running a scat crank with 6.385 H beam rods in a 540.
No complaints.
Noise Pollution is offline
Old 01-21-2008 | 09:01 PM
I use Eagle. Just seem to have less issues than the Scat's.
ghittner is offline
Old 01-22-2008 | 10:03 PM
1CE
saw a Scat crank with it's nose/snout---torn/sheared off, it was on a blower engine, prob. over stressed OR just a fluke forging.
1CE is offline
