ls2 heads
Fast,
Combustion Chamber Volume: 64.45cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Valve Angle 15º
Solid Stem valves
Flow .200"-.600"
Intake Exhaust
136 104
195 135
237 157
260 169
260 180
Bob
Valve Angle 15º
Solid Stem valves
Flow .200"-.600"
Intake Exhaust
136 104
195 135
237 157
260 169
260 180
Bob
If you trust this guy http://www.quicksilvertrucks.com/for...read.php?t=216
Valve Material: Stainless Steel, Hollow Stems, Na filled Exhaust
The LS6 & LS3 had/have the hollow stem sodiums, the LS1 did not. The LS6 & LS2 heads are extremely simular castings, the only difference being the sodium valving in the LS6 heads, with "yellow" valve springs, which simply denotes seat pressure.
2.16" Intake Valve
1.59" Exhaust Valve
70cc Combustion Chamber
260cc Intake Runner Volume
90cc Exhaust Port Volume
Flow Data:
Lift, Inches Intake Flow @ 28" Water
With 4.125" Bore
Exhaust Flow @ 28" Water
With 4.125" Bore
.100 79.2 57.8
.200 153 114.4
.300 225 147.2
.400 276 170.3
.500 309.6 183.1
.550 323.2 186
.600 332.2 189.5
.650 327.7 191.1
.700 330 192.6
.750 317 195
.800 317 195.8
lots of corvette or pontiac gto owners buy these heads as a low cost ($450 These heads are sold complete with valves, valve stem seals, keepers & retainers.) powerupgrade
I am building a ls 2 engine whit this heads in to a 21ft phantom
if youre looking for a power upgrade better can take the L92 truck version head used on the ls 2 blocks and complet l92 truck engine they have bigger valves(stainless steel) and better flow!
2.16" Intake Valve
1.59" Exhaust Valve
Flow Data:
With 4.125" Bore
With 4.125" Bore
.100 79.2 57.8
.200 153 114.4
.300 225 147.2
.400 276 170.3
.500 309.6 183.1
.550 323.2 186
.600 332.2 189.5
.650 327.7 191.1
.700 330 192.6
.750 317 195
.800 317 195.8
2.16" Intake Valve
1.59" Exhaust Valve
Flow Data:
With 4.125" Bore
With 4.125" Bore
.100 79.2 57.8
.200 153 114.4
.300 225 147.2
.400 276 170.3
.500 309.6 183.1
.550 323.2 186
.600 332.2 189.5
.650 327.7 191.1
.700 330 192.6
.750 317 195
.800 317 195.8
7K rpms with the right combo. I would use the L92s on larger bore motors like a 383 or 402 or bigger.
