Morel lifter??
Are Morel lifters a direct replacement (same height) as stock roller lifters on a 502 mag? I just spent a fortune on custom length pushrods and don't want to do it again.
Call or pm RMBuilder/Bob Madara of Marine Kinetics....he can help you with your questions.
Originally Posted by KAAMA
(Post 2421384)
Originally Posted by kennyo
(Post 2420723)
You need to measure the inside of the lifter where the pushrod is inserted, the outside lip of the lifter is not important.
Why did you get cusom length rods? where the rockers rubbing the retainers or what? |
(Post 2421642)
Why did you get cusom length rods? where the rockers rubbing the retainers or what? I changed many things that could (and did) effect the length of the push rod. Using the method best explained on most push rod manufacturers websites, I validated that to be true. |
I did a cam and roller rocker change. the rockers and studs warranted the the new pushrods.
(Post 2423241)
You need clearance under the retainer, and the roller tip needs to be in the center of the valve stem when the valve is open. Even if you use a length checker, you will have to mock the engine up. If the pushrods are a little short, sometimes you can put lash caps on top of the valves and it will keep you from ordering a longer rod. Good luck with your project. |
(Post 2423293)
Best way to find out is to mock up the engine and stick a lifter in the hole and see if the rockers line up properly.
(Post 2423483)
I used lash caps once to get dead on. They always made me nervous though. I'll get it right, it's gonna suk if I have to change them though.
Most of mine have little or no use on them because of similar situations. I ight be able to trade or help you out a little. Jeff |
The Morels are designed to be a direct replacement and use the OEM length for the hyd roller Gen 6 engines. Whether you use retro fits or drop ins the pushrod length will be the same.
(Post 2420723)
http://store.summitracing.com/egnsea...=KeywordSearch |
Originally Posted by cstraub
(Post 2423590)
| All times are GMT -5. The time now is 04:20 AM. |
