headers or manifolds stock 502 >
Old 01-26-2008 | 11:37 AM
266ltd's Avatar
Default headers or manifolds stock 502
who makes the best, ie. the most horsepower for the money? There are so many options out there it is hard to chose from all and make a dissision. i am also planning on making some minor mods next winter also.
266ltd is offline
Old 01-26-2008 | 12:18 PM
Wink
In the most horsepower for the money and pretty good looks to I would vote Dana Marine as tops!
Regards,
Ray @ Raylar
Raylar is offline
Old 01-26-2008 | 12:51 PM
Lofty's Avatar
There are some great products out, Dana is one of them. Keep in mind you may have to relocate a few things and this will add costs. If you shoot me a pm or post some pics of your application I can help you get it spec'd out.
Lofty is offline
Old 01-26-2008 | 01:32 PM
Before you all go making suggestions on exhaust manifolds, it is important to know what C.I. displacement the motor has? I know that he wrote "stock 502", but he went on to write "some mods" too. Does that include increasing the displacement?
ROTAX454 is offline
Old 01-26-2008 | 04:44 PM
I had Danas on my stock 502mpi and I liked them. sounded good and was the most bang for the buck. It was on my lod boat 272 baja.
I DIG IT !! is offline
Old 01-26-2008 | 08:32 PM
dana marine products's Avatar
The DMP manifolds have larger primaries and more flow ability than 1 7/8" tube headers. Our risers are available in 3 different inside diameters to accommodate a very wide range of HP.
dana marine products is offline
Old 01-28-2008 | 06:31 PM
What is the runner length?
ROTAX454 is offline
Old 01-29-2008 | 12:35 AM
KAAMA's Avatar
I think you're heading in the right direction, but it will depend on the mods you're doing to your engine. What kind/cubes, HP rating of engine is your engine? If it is a stock Merc engine, then you will see very little if any of a gain at WOT by just bolting on a set of aftermarket exhausts, however you may notice more a nice kick in the midrange excelleration.
You're doing the right thing by adding a well breathing exhaust system FIRST! Depending on the upgrades/mods you do, then the more a better breathing exhaust system is going to work for your engine to give you more speed at WOT or peak/upper RPM ranges.
Much of it depends on your engine's cubic inches and the application....I would think a good quality aftermarket manifold type exhaust system like a Dana Marine exhaust, Stainless Marine or something comparable to those would be suitable for your engine. Besides the big weight savings, they will dress up your engines nicely as well.
Somebody correct me if I am wrong, but I highly doubt the high dollar tubular header type of exhaust systems will out perform a manifold system unless you're entering at 540 or larger cubic inches.
Hope this has helped. Have fun.
KAAMA is offline
Old 01-29-2008 | 01:33 PM
The DMP manifolds with our Vortex riser make a 27" long runner. Almost twice the length of a traditional 1 7/8" tube header. (15 1/2")
Old 01-29-2008 | 04:09 PM
The Eickert cast header has a 32" runner length. Are we to believe that this was specifically designed by Keith for a 502 C.I. motor?
http://www.keitheickert.com/detail.aspx?ID=7773
ROTAX454 is offline
