Shining up discolored drive???
My drives have a slight cloudy discoloration to them. I tried to use hull cleaner then polishing compound and still discolored.
What's the secret to getting rid of the cloudy look of them? |
Originally Posted by East Coast B
(Post 2422449)
Are you running drive showers? If not that could be some of the cause. Dirve gets hot when running.
Originally Posted by Noise Pollution
(Post 2422676)
try toilet bowl cleaner... The Works toilet bowl cleaner to be speific
Originally Posted by fountainguy214
(Post 2422691)
Originally Posted by formula 382 sr-1
(Post 2422696)
Tried it still looks like $!#% . I use the works to get hull stains off .
Looks like those drives are gonna need a repaint :evilb: |
(Post 2422728)
I do the same for the hull...
Temp fix squirt WD40 on them. Sometimes will help.
Medium term solution I taped up everything including the transom and the decals, scuffed the dull paint with 400 grit and spray painted with the can Merc Phantom Black. Looks fine. |
Originally Posted by Thunderstruck
(Post 2422777)
| All times are GMT -5. The time now is 06:36 PM. |
