575sci HEADGASKETS AND WHILE I'M IN THERE???
Registered User
On what-to-do while you're in there, I'd throw a new set of valve springs in.
Pick your blower/intercooler/etc., then have a cam ground by Clay Smith or rmbuilder to match your combination exactly.
Probably the best bang for the buck is the chiller on your existing setup. The Whipple is nice but $$$.
Thanks for your feedback Steve. I like the low-profile whipple but it may not be low enough. If I have to modify or replace the hatch I will most likely do the Superchiller...just need to get into storage and take some measurements. The HP loss in warm water on warm days was VERY noticable.
Do you know what else AZSM does to the ECM other than the rev limit?
There is some HP to found on a SC motor (particularly the low compression 575) just by spinning it and the blower faster (more boost with more RPM = more HP).
As mentioned earlier, run the FelPros or Cometics, and check the heads (valves, seats, springs, retainers, surface) while you have them off.
Steve
Bill,
Are you running intercoolers?
When I got my boat it had the 3.5 pulleys and the GPS recall had 95 on it (probably a strong current and tailwind that day). I went back to the stock pulleys and have only run a best of 89 but can't turn above 5000rpm. Thinking the intercoolers will wake it up and work with my props. The Whipple kit comes with a 3.25" pulley.
. I trien the 3.25", picked up 1 more MPH and showed 5PSI. I put the 3" on and got back to 6PSI intercooled, and a gained a total of 5 MPH from the previous non-intercooled 6PSI 3.5" set up. This was in cold weather when the intercooler was at it's most efficient, but my boat was much more consistent than it had been in the past, even in warm weather and water.Here's a pic.
Steve
Registered User
All a Merc spring will accomplish is a faster lightening of your wallet. Any good spring will work.
I have read comments recently about some ultra-high-end springs and their unsuitability for use at extended low-RPM. Don't know why but they're rumored to have failed in these situations. Unless you're running .700+ and big RPM, there's no advantage anyway. The secret is getting them in at the proper installed height/seat pressure.
Hey guys, I have really enjoyed reading your post. I hadn't visited OSO in a while, but w/ the season approaching I figured I get back in the game.
Here's my experience w/ 575's: I have a pair in my 35' Lightening w/ Super Chiller's & aluminum Merlin’s. 1st of all I was new to blower motors, so I can tell you to go thru the blowers every 150hrs. Positively no more than 200 hrs unless you want to ruin one like I did! Secondly, watch the head gaskets. This is all stuff you have covered but I ruined a motor at 281 hrs because of a gasket failure.
Here's my question for you: Now that I have added the Super Chiller's, when the motor is cold and I am idling out of my marina (this takes 4-5 minutes), both motors load up real bad. I'm assuming this has to do with fuel puddle'ing on the top of the intake. When I go to take off I get BLACK smoke out of the exhaust and it takes a second to clean up. I have to change spark plugs with every oil change now (25 hrs).
I’m thinking the Whipple’s might have been a better choice. I didn’t want to flip the coin for them but considering it is a fully integrated intercooler and intake, it might flow smoother, instead of just dropping the fuel on top of the intake.
Any thoughts/suggestions??
Quaid,
2-things come to mind. Did you have the ECM remapped? Whipple leans out the mixture. From what I have read Merc programmed them on the rich side to be conservative.
Are you pumping water through the chillers at idle or do they pick up the water under way through pickups? If you pump water through the chillers it will cool the intake too much at idle and run rich.
Good luck and let us know what you find out.
Woody
Woody
Woody,
My ECM's are not reprogrammed but yes, I did use pick ups.
So Merc has the motors fat at idle? I could see them being fat at WOT but why would they make it fat at idle? Before I added the Super Chiller's it never, ever did anything like this before. I would change my plugs once a season (100 hrs).
Should I also swap to an MSD ignition system as well?
Who should I use to reprogram the ECM's? Teague sold me all of my parts and never mentioned reprogramming the ECM's.
Woody,
