piston rings
Carm,
I personally have not seen a big advantage to the gapless rings. I have only put them in an engine one time at the request of a customer.
Depending on the bore size, more often than not, I dont even order the file fits to begin with. If the bore is new and the correct size, most of the time the non file fit rings will be pretty close out of the box. Sometimes you even have to file them some. If i do need file fits, I generally use Speed Pro. They are a pretty tried and true ring that works well and does not have problems.
Just my opinion,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Just my opinion,
Bill Koustenis
Waldorf Md
I know the circumstances are different, but maybe this will be food for thought. I once built a small block chevy drag race ( car ) engine with gapless rings and gas ported pistons. They sealed real well, but didnt last long. I would not use them again.
like vinnyp ,i also built a drag motor and gas ported the pistons.they sealed real good and looked good on the gage,but the bores wornd out quicker.i would use speed-pro rings and check the bore as said before.just my 2cents worth.
Registered User
This is an interesting thread. I am about to start a new engine for the boat and was intending on using gapless rings. I have used them in the past with good results in non-marine applications, but would like to hear some more experiences in boats. Maybe I will re-think my descision.
For this application stay with a Speed Pro premium moly ring set. I personally prefer file fits so I can dial in what I want for end gap per build. On this engine I would gap the top ring at .018 and the second at .016. There is alot of specifics when you start talking about rings and sealing. Here again depending on the application certain ring packages will work better than others. Ring widths, tensions, styles, and finish hone all will fit specific engines. I have run Childs and Albert ZGS rings in performance marine applications and they work very well. This is a Zero gap second ring with a standard moly top. With proper hone cross hatch and finish grit , maximum power and longevity can be achieved. Alot of trick technology is in this area right now! But remember, Drag Racing is Drag Racing and Marine is Offshore endurance!
