starting complete dash remodel.. >
Old 02-06-2008 | 10:34 PM
Steve_H
its .125 aluminum.
if i was to do it again i would probably use .063
.125 was a little overkill.
Old 02-07-2008 | 06:55 PM
I just finished mine this week, I used Lexan. I like the aluminum look better. I wish I would read your thread. Damn
jbraun2828 is offline
Old 02-08-2008 | 06:17 AM
ak
Default dash overhaul
i also redid my dash last winter and it is the best looking part on the boat,i removed all the gauges and then removed old plastic junk panels,i then had a tool and die buddy copy the plastic panels on a cnc program and made them out of 1/8 aluminum plate,i then trail fit them,fit great,so had a body shop paint them yellow (boat colour)and then got a place to screen print all the label for the switchs and even threw in a baja logo,looks great,and updated it perfectly.
ak is offline
Old 02-08-2008 | 10:03 AM
tblrklakemo's Avatar
SeaRay Sundancer
we are doing something similar in this thread.....
http://www.offshoreonly.com/forums/s...d.php?t=179332
Do we need an engine sync gauge? Still trying to figure out drive trim indicators too since those are on the old dash.
tblrklakemo is offline
Old 02-08-2008 | 11:28 AM
nocigarette's Avatar
Originally Posted by Steve_H
its .125 aluminum.
I did the same thing it was a little thick.....
Went from first pick to the second....third is the dash up close..
The beauty of sheet aluminum is you can just trace your old panels and paint it whatever color ya want....
Attached Thumbnails starting complete dash remodel..-img_0497.jpg.jpg   starting complete dash remodel..-copy-5-magnum-130.jpg   starting complete dash remodel..-magnum-095.jpg
nocigarette is offline
Old 02-09-2008 | 06:20 AM
DONZI's Avatar
Originally Posted by waterboy222
damn, $20/each and its just the COVER! i was wanting to do all my switches but by the time i bought 25 of those and 25 switches ill be way over budget...thanks for the link though.. i may end up just doing a couple of them like you did and make them start switches..
Here are some basic ones you could paint also. Combine some in the 3 hole ones at $18.00 ea.
http://www.aircraftspruce.com/catalo...evswitches.php
DONZI is offline
Old 02-09-2008 | 11:36 AM
Jammin''s Avatar
Tip on source of .125 aluminum. I go up to the county facility where they deal with street signs, climb in the dumpster and get my .125 aluminum there. The stop signs are that thickness.
Jammin' is offline
Old 02-09-2008 | 12:02 PM
Elite Marine's Avatar
If there is anything we can help with let us know.
Full Line Livorsi, CP Performance and Rex Marine...should have anything you need covered!!
Kirk
Elite Marine, Inc.
Elite Marine is offline
THEKID29FEVER
Fountain
1
05-19-2008 05:29 PM
dyno
1
06-26-2005 08:11 PM
tripps
05-05-2002 08:18 AM
