Roller cam bearings
Anyone using Torrington style roller bearings for you cams?
If so, Did your bearing casings need to be drilled for an oil feed and what size feed did you use?
I wouldn't think ya wouldnt need it in a regular marine application ,unless its race stuff 50mm cams.Ya might try Crower,I think there the first ones to make a cam for the needle bearings. they called it Inrad.They have the SBC 50mm cam size at 1.968 and the 55mm at 2.165
Find someone that has one of these.Hopefully they will know how to use it or atleast know what it is
http://www.bhjinc.com/1products/04-B...entfixture.htm
