exhaust question >
exhaust question
exhaust question
Old 02-12-2008 | 09:30 PM
Years ago, I took some 5" diesel steel pipe and made a double 90 degree ell that I was needing in my boat. Then I got it hot dipped galvanized. It never failed. Also, those cast iron risers cost me a few motors when the gasket failed. Just my 2 cents.
THLWL is offline
Old 02-12-2008 | 10:01 PM
how did they cost you a few motors? what did you do to change it?
jlaudio29 is offline
Old 02-12-2008 | 11:24 PM
You need to change teh gaskets between the manifold and riser at least every year or 2. If they fail, water will seep back into the engine. It will hydrolock and bend the rods.
Griff is offline
Old 02-12-2008 | 11:27 PM
Originally Posted by jlaudio29
it is defaintly a switchable system, however i think it is only switchable between Quiet and mixed ill try to take them off tommarow to get a better look at them, just need to see if i have the pipe at the shop
The exhaust will take the path of least resistance---which is straight out the tips. Very little will go out the prop even if its mixed.
BTW, a stock 454 in a boat will be quite a bit quieter than open headers in a car. The boat exhaust is muffled with the water mixing with the exhaust.
Griff is offline
Old 02-13-2008 | 10:41 AM
The cast iron risers to manifold connection will get eat up with rust on the i.d. (I was in salt water use). Water can leak in to your engine and you can't see it. Merc. tried to resolve this by making a SS riser. However, the SS riser expanded differently than the cast iron and again the gaskets failed. My final resolution was to replace the cast iron manifolds with Stainless Marine units. No more issues.
THLWL is offline
hpy540
8
11-22-2005 07:14 PM
THE GOOD STUFF
03-03-2004 09:17 PM
formula1
05-25-2002 07:59 PM
thisistank
Baja
17
03-24-2002 10:50 AM
