New SBC ready to go!
I spent the last couple months putting together my new stroker. Fired it up last week and plan on installing in the boat early next month. Just wanted to throw out the specs and eye candy to other bored boaters during this long winter.
Specs.... 385ci SBC 010 4 bolt SBC, bored .040", 0 decked, line honed, ESP 4340 3.750 crank, ESP 6" 7/16" H beams, Mahle forged FT's 5cc, C77H bearings, Hines Balanced Melling Racing #10555 oil pump, Hamburgers 7qt marine pan, full length windage tray. FluiDamper harmonic balancer, AFR 190cc heads, 73cc, further ported by Carl McQuillen Racing Engines, Isky 6105 dual valvesprings, Marine Kinetics "RMbuilder" custom Hyd Roller 234/240 .580/.568 112+4 Morel Retrofit Hyd Roller lifters Smith Bros .083" wall pushrods Edelbrock RPM Air Gap port matched to AFR port Holley HP 750 DP Lunati Voodoo Widebody 1.5 roller rockers Glenwood aluminum Magnaflow manifolds FastGlass Stainless 16" long risers Full MSD ignition setup, coil, wires, dist, 6AL, 10.07-1 SCR With my 23P labbed cleaver it should spin to 6000rpms. Right in the peak power range of the custom cam. I had a few droplets of water in the center runners of the manifold after the reversion check so I will be extending my risers another 4-5". That will put them right in the middle of the tip killing the reversion. Right now the water mixes 4" before the tips. It's going in my 1984 22' Hammond Challenger MKII This pad bottom hull is very light 1800lbs dry and it should fly. I'm shooting for high 70's maybe an 80! :D It ran low 70's GPS all day long last summer with a 355ci AFR headed motor. 76GPS on a cold day was the highest I saw. http://usera.imagecave.com/ryanootj/...iringstand.jpg http://usera.imagecave.com/ryanootj/DSC00279.JPG http://usera.imagecave.com/ryanootj/DadvsSkip.jpg |
Nice!!......bet it sounds sweet!
that's got to make some torque I've never run the AFR's with the air gap myself but it should realy make some suds best of luck let us know how fast when you install it Sincerely Laz
www.mesabalancing.com |
Nice work. Looks like a stout package, and in that lite hull, it should really fly.
Darrell. |
2 Attachment(s)
Ryan, That package should put a smile on your face. Last fall I built and installed a similar eng. Had it on the water twice b-4 the lake got low and winter set in. Found a few things that needed correcting. My 383 has the AFR's 195 Elim. w/ 65cc heads, 6" rods. all forged bottom, mahle 16cc dish pistons, O decked, .039 Felpro head gasket. Bullet Cam (Ultradyne) 230/238, lift .540/.525 and set at 111.25 w/ 4* adv. I would of liked to dyno'd eng. but that seems to be a problem in the Atlanta area. Even the speed shops was hesitant to recommend. Ryan i'll be in touch (PM). here is a pic of mine.
Originally Posted by tmdog
(Post 2453147)
tmdog, Sounds like a runner for sure. I'm envious of the Eliminator heads. After the additional work my 190's flow almost what the 195 Elims flow. What exhaust are you running? If I can get a deal like last year on an engine dyno day i'm going to throw mine on and see what it makes. A few shops and engine builders said with 1.75" dyno headers around 475-490hp. I would love to see the difference between them and the boat exhaust. Unfortunately I can't see your pics as I am a regular user. Shoot them to me at [email protected]. |
nice.......!!!
Ryan
Looks like a pretty nice piece. Do us the honor of posting a video on youtube of it running when you get it in the boat. Two of those would be real nice in my 28 cig. tmdog, how do you like that DUI ignition? |
Had the DUI for 3 yrs. Easy to hook up and reliable. Dist. is marine approved. Factory set it up w/ 22* advance at 3200 rpm. With initial timing set at 12*, have total timing 34*.
| All times are GMT -5. The time now is 04:19 PM. |
