-   -   True or False: MEFI 3 has TOTAL run time? (https://www.offshoreonly.com/forums/general-q/180694-true-false-mefi-3-has-total-run-time.html)
Fast Algae 02-25-2008 03:14 PM
I was told by one person they could only get the current time the engine was running, (as in right now) and by another that the total time is on the computer.
Anyone?
mrhorsepower1 02-25-2008 03:18 PM
It records the total run time.
CigDaze 02-25-2008 03:27 PM
Lifetime total is recorded.
bob_t 02-25-2008 05:08 PM
You can get both, just did this last week with Rinda ScanMate. First it shows total run time, and then when it goes into "scanner" mode, it will tell you how long it has been running, currently, since scanner was attached, along with a bunch of other "current" information.
Fast Algae 02-25-2008 08:55 PM
Thanks!
Whipple Charged 02-26-2008 04:17 PM
Yes, it also breaks it down into rpm intervals. You can also see the amount of time in knock retard. This can all be erased if you have the right software, so you can't always trust the hours.
Dustin
Fast Algae 02-26-2008 07:44 PM
MEFI 3 does that? I thought it had to be the new, next generation (can't remember the name/number) that breaks down the rpm stuff?
Whipple Charged 02-26-2008 10:04 PM
Yes, MEFI 3 does that as well. It doesn't break it down quite as much as MEFI4, but it certainly breaks down. Problem is, no current hand held scanners show the info. Maybe MEFI burn does, but not sure.
Dustin
Young Performance 02-26-2008 10:11 PM
Dustin,
I once borrowed a scan tool from a friend that did show the entire break down of hours vs. rpm. I believe it was made by OTC. I not positive about the name, but I'm pretty sure. It had interchangeable cartridges that would allow it to work with all of the MEFI's and the 555, etc. It was a really nice piece. The only problem was it is a little big. It is probably 5 or 6 times the size of the Rinda.
Eddie.
Smitty 02-27-2008 09:34 AM
My Rinda tool shows total hours, but not individual times at any rpms.
