Hp 500 Help
I have been searching the threads but no luck yet, I have a 2000 HP 500 and i am looking to redo the heads and want to add some more power what suggestions do you have, cam, exhaust, ? Thanks Kickin32
those have rectangle port heads don't they?
Go with a set of aluminum AFR's.(air flow research). I've heard very good things about them from many engine guys.
Darrell. |
We have done cnc ported aluminum heads, camshaft, Modified carb, and Msd ignition = 600-620 HP. Tyler
Tyler where are the new intakes for the fuel injected motors you designed, are they done and perfected yet. If so what numbers are we looking at price wise.
Kicken,
Give me a call, as I can help you with any and all of your engine and boat needs. We can do a few simple mods or take it to over 800 hp. The choice is yours. Everything I build is warrantied. Thanks, Eddie. |
Kicken, Tyler did my 1999 500 HP's last year, gained about 100 hp, with conservative modifications, jumped about 4 prop sizes to get dialed in... Can;t wait for this spring! Carder
Originally Posted by 45SS
(Post 2463975)
I know Tyler's motor have rode in several boats with them and they are strong!!, I was trying to get some ideas of what to do . I know my heads need to be redone so i was figuring while i was doing that to do a few other mods. Thanks for your help.
| All times are GMT -5. The time now is 05:21 AM. |
