-   -   Hydraulic steering or counter rotation? (https://www.offshoreonly.com/forums/general-q/180995-hydraulic-steering-counter-rotation.html)
spazboz 03-09-2008 12:39 PM
Typically if the boat leans to the starboard, thats an indication that the driver/operator needs to loose some weight. :p If the boat is listing to the port, best thing you can do is NEVER say a thing to your wife! O'h and yes, good idea, blame it on the drives...
jlaudio29 03-09-2008 01:45 PM
haha g1
CCstinger260 03-09-2008 10:32 PM
Originally Posted by JimmyBaja (Post 2477402)
Note: You only reverse the shifters if you are running bravos. The shifters are not reversed for alpha counter rotating drives.
Not true. You must switch the shifters on Alphas-unless you want to run with one shifter in forward and one in "reverse"
JIMG 03-10-2008 08:43 AM
you absolutely must change the shifters on a counter rotation alpha. CCstinger is correct. I've been there & done that.
